The Single Click Of Doom!!!
xweav32
Car: 2011 Nissan Versa S 6spd (daily)
1995 Nissan 240SX SR20DET 5spd (fun car)
ok i just finished swapping a new ( well used) SOHC into his hatch. we were cranking it over fine and one of the battery terminals came loose and sparked. after that the starter just clicks once and then nothing. try it again and the same thing happens. GOOD BATT and ALT. so its not that. i know my way around a 240, but dam this is perplexing.
just one click then nothin.
we swap starters from the old car and still have the same result.
hammer trick, still nothin.
So what is it? bad ground, blown fuse, blown relay?
car is a manual btw.
please help we're on a limited time frame and we need to get it runnin. any help would be greatly appreciated!
thanks zach.
xweav32
bump please! im gonna recheck everything but i want you opinions please! ive searched this **** and came up with nothin!
pflicht
Car: 1991 Nissan 240sx - SOLD
2000 Lincoln LS - DEAD
1997 Nissan Maxima - DD
1991 Nissan 240sx - Project
Can you pop the clutch?
xweav32
well the clutch isnt hooked back up and ther isnt any fluid is the system. i would imagine it would crank and start though if hooked up.
im leaning towards the relay but im still gonna recheck it all. it was cranking fine till the look terminal sparked.
assassin7420
Car: 1996 Nissan Silvia
1995 Nissan 240sx (daily)
Check the relay,fuse. I had a similar problem with mine. Poped the fuse after the first click and lost power to everything. Tracked down a burnt up wire later and problem solved.
xweav32
will do. what wire burnt up?
assassin7420
xweav32 wrote:will do. what wire burnt up?
No idea but it was wired into the IGN. Who ever wired the car did a piss poor job and im slowly fixing it. I just cut it so it would stop shorting out and poped in a new fuse and it started up fine. Its been about 2 months now and hasn't given me another problem.
hpmachine
Car: '05 EVO8 + '95 240sx
Check all the simplest stuff first. Make sure you have good contacts on your battery, good ground, check your fuses, then relays, etc. oh yeah, not to thread jack or anything but do you have a passenger side corner light for sale from an s14 zenki?
xweav32
cool thanks for the help. ill check that too. this is why i loved my 95. the least amount of wires of any year. simplicity is god.
my buddy bought a parts 240 for 200 bucks and it has all the relays and fuses in it, so ill replace the inhibitor relay and go from there. it would be nice if this fixes it because when it was cranking it was firing. turns out the fuel lines were backwards. we fixed that and now the starter crap. so im hopin i get it fixed.
if you have any other ideas let me know!
assassin7420
As usual check the grounds and the main power wire from the batt.
xweav32
wich corner light? i sold the ones on the bumper with the bumper. the one s next to the headlight are cracked really bad. you still interested in that femder too?
ceno
Car: 1995 240sx
Same thing happened to me, it was the 75a master fuse.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
check fuses. double check your work, sounds like you guys are rushing- loose terminals, backwards fuel lines, no fluids? good luck man.
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
srpowered240sx wrote:check fuses. double check your work, sounds like you guys are rushing- loose terminals, backwards fuel lines, no fluids? good luck man.
you like nit picking at everyone dont you? almost everytime i see a post of yours your trying to tell them theyre doing it wrong
srpowered240sx
leedrift wrote:you like nit picking at everyone dont you? almost everytime i see a post of yours your trying to tell them theyre doing it wrong
just trying to help, if it comes off as "nit picking"......well, i still dont care, you dont like my opinions or advice, dont heed them. ive helped waaaay to many people on this board to care what you think of my advice.
Encryptshun
Car: 2005 Nissan Xterra
srpowered240sx is a long-time member in good standing and he's helped people who were laughed at by the rest of NICO. If you're gonna throw down, chump, try aiming at someone who actually deserves it. Otherwise YOU end up looking like the douchenozzle. And considering it looks like you are here primarily for the Classifieds, you might not want to be a jerk if you can possibly avoid it. And he *did* try to help. Just because you don't like the experienced advice he gave, don't go p*ssing into the wind.
srpowered240sx
thanks buddy. dont worry, im filing this leedrift characters name away in my memory banks of people to avoid when helping troubleshoot, doesnt understand or appreciate beneficial info.
Clawhammer
Ignition switch.
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
you think beneficial info is checking fuses and connections? my 5 year old cousin would know that. and im not thyting to be a "chump" or a "douschenozzle" i just dont like it when i see smart comments like well its a 18 year old radiator of course its gonna blow up. saying stuff like thats just gonna piss the person off more. if hes having trouble hes gonna be mad and seeing stuff like that will jsut make it worse. im sorry if i offened you but i see alot of "douchenozzles" on here for omly being a member for like 2 months and i think its dumb
srpowered240sx
leedrift wrote:you think beneficial info is checking fuses and connections? my 5 year old cousin would know that. and im not thyting to be a "chump" or a "douschenozzle" i just dont like it when i see smart comments like well its a 18 year old radiator of course its gonna blow up. saying stuff like thats just gonna piss the person off more. if hes having trouble hes gonna be mad and seeing stuff like that will jsut make it worse. im sorry if i offened you but i see alot of "douchenozzles" on here for omly being a member for like 2 months and i think its dumb
dont like it? gtfo. i say what i want, im not gonna patronize someone and say "awww, man, too bad, anything we can do to make you feel better?" we are here to help each other, joke with each other, and generally share knowledge. i have yet to see you make a helpful statement to anyone, so again i say, if you dont like it here after being a member for two whole months, then gtfo.
Vegascorbin
Car: 1990 240sx dirt track race car
Just because the advise is simple and something most people would think of DOES NOT MAKE IT BAD ADVISE. What srpowered240sx originaly said was right on the money. They are rushing the job and need to slow down and check the obvious things FIRST. If they come back and say we checked all the fuses and relays and grounds etc then telling them to check that would not be proper.
Their reply to his original advise was that they were going to check fuses etc.
By the way, leedrift I saw NO advise from you on what the problem might be. If you have better advise, speak up, otherwise just keep lurking on the sidelines and stay out of the way of those of use that are trying to REALLY help those that need it.
--- ] --- ]steping down from my soap box and returning you to your normal thread.
hpmachine
xweav32 wrote:wich corner light? i sold the ones on the bumper with the bumper. the one s next to the headlight are cracked really bad. you still interested in that femder too?
No. Thanks anyway man.
xweav32
hey fuk tard. if you red the first post i said i was gonna look over it again.
as for no fluids the motor USED. you probly didnt see that either. so if ther was say rod knock? thats one last thing to disconnect.
leedrift happens to own the effin car neither one of us are rushing we know what we are doing.
the car happens to be running now the connection was sh1ty.
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
yeah and its not that i dont like advice its that you dont have to be a smart a$$ about it. yeah and it is my car. thats why i have nothing useful to say
hpmachine
Oh wow, was I kind of right? Simple stuff ftw?!!
xekushnr
Car: '90 Nissan 240SX Hatch
Wow haha, I think you guys will be on your own next time.
srpowered240sx
so what your saying is im a fuktard for telling you that you guys were rushing, even though i was right and you had a connection that was put together hastily. hmmmmm, sounds like i dont know what im talking about. you guys have hoses backwards, connections not plugged in properly, and you are trying to start a motor that was not even complete, and im the fuktard? ill make sure not to suggest anything the next time you morons have a problem.
Clawhammer
What is this? Zilvia? Yeesh.
SR, just take your help where it's appreciated, don't bother with these assclowns.
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
it wasnt a connection it was a bad relay
hpmachine
This is a weird thread...
