The RPM range of engines while they're drifting
Kalypso
This is the first thread ive created in a while because I think it will make for interesting discussion.
what is the effective rpm range of an engine while the car is drifting, presumably on a windy track.
Kalypso
it seems that it would be in the higher ranges of 3.5k to 6k
but this thread is too quiet to know for sure
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
I would think that It would depend on the engine. I drift in a mid-to-high RPM mostly. But I sometime's like to get it into a mid-RPM range just because my stock exhaust mani will glow bright pinkish-red after running it hard. I hear some people bouncing off the rev limiter!
I would think with a motor with more low end torque like an ls1 would drift good at a mid rpm range.
So all in all I would guess its some where in your motor's power-band.
jr_ss
Car: 95' S14
It was really depends on what gear you're in, lower gear, higher rpms and the opposite for higher gears... You'll probably spend most of the time in the higher rpms with the lower liter motors, close to if not on the rev limiter...
xpicer
Car: 1990 nissan 240sx
when i usually drift ( sadly i am not able to go to tracks that often) i usually stay on higher rpms and or try to brake the wheels loose by down shifting and then i go on the next gear and balance the power in the mid rpms
Kalypso
so the engine, is working hardeven in 2nd and 3rd gear. between 4.5k - 6k rpm
I brough this up, because most of the NICO buildthreads are dedicated to the garrett gt2871r
it would seem that a top mount setup is better for drifting, open highways, and autoX tracks with decent straightaways
topmount turbos setups are underrated waiting unitl 3k rpm for full boost isnt unreasonable
xpicer
the only engine i have ever drifted with in the low rpms was on a rb25det /s13
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Kalypso123 wrote:waiting unitl 3k rpm for full boost isnt unreasonable
Most top mounts will spool in the mid to late 3's some even in early 4's. It's still not bad at all. EVO's spool in the mid 3's stock. People just whine because the T25 spools so fast.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Top mount is such a bland statement. It just dictates where the turbo sits. What justifys spool is the turbo size, runner design, and turbine housing (T2, T3, T4, etc.). For drifting it wouldnt be smart to go anything larger than 3071R on the SR20. Maybe GT30R if you had a stroked SR22. I think a 2871R T3 setup would be very responsive.
Kalypso
DrifterProdigy85 wrote:Top mount is such a bland statement. It just dictates where the turbo sits. What justifys spool is the turbo size, runner design, and turbine housing (T2, T3, T4, etc.).
top mount is very general you're right, Im pointing at turbos with the t3 foot print and the added boost that goes with them.
gt3071r is a good mid to high rpm turbo, so I guess that answers.
DrifterProdigy85
Also you can go Twin Scroll setup which gives an increase in midrange tq as well.
Kalypso
yeah, and I am also realizing that the best, and most affordable way to do a twin scroll manifold is to make it yourself.
but what I was getting at, is the downsides of a big spooling gt30 turbo or even a t3, aren't as severe as people say.
In fact they may be better suited for drift, and highway driving.
As to where a gt28 is better for light to light, and autoX'ing.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
my next turbo upgradeT4 Twinscroll TS360-35R
Kalypso
I just realized that this thread is pointlessbecause you can drop the clutchwhen your good and ready.
supreamS14
Kalypso123 wrote:
I just realized that this thread is pointless because you can drop the clutch when your good and ready.
Yep, you can weight transfer in neutral and still drift. Because of my 2-way lsd I can brake and go into a drift. But I love to do long drifts so Im always on throttle.
Kalypso
Idaho that borg warner turbo is out of this world
GO240
Car: 1990/1/2/3/4/5/7 240sx lol
4500+clutch kick= 6000 drift my SR won't rev higher in a drift for some reason
Kalypso
wait... im slow, so you're at 4500, you kick the clutch and hold the throttle - the motor revs up to 6000
as you release the clutch and re-engage the rear wheels you drop back down to 4500...
xpicer
i belive he says that while drifting he can not get his rpms higher then 6k , maybe a fuel cut out ????? from what i can remenber i could jump off the limiter at anytime if i wished
