ISUJinX »
https://forums.nicoclub.com/isujinx-u50362.html
Tue Jan 02, 2007 4:28 pm
As long as they are good quality wires, they are pretty much all identical. The biggest difference is in the use of shielding to reduce signal loss from electrical "Noise". Get shielded wires if you want best spark. For 200hp, you're definately looking at port and polish, cams, re-tune, and higher comp pistons. If you go with the KAe pistons, it puts it at 11.7 IIRC. That is just about the upper limit of compression you can run on 91 octane. If you have 93 where you live, you might be able to get 12 or 12.5 dome pistons from an aftermarket supplier. Be careful with dome pistons though, because they start to weigh more, and high rotating mass is not condusive to higher revs (which is where you will see the power increase).
