Spilk188 »
https://forums.nicoclub.com/spilk188-u8442.html
Tue Jun 15, 2004 11:41 am
Ok, so my friends and I are driving back down from another one of our friend's houses at 3am this morning. My friend Chris is driving his 1994 Mitsubishi Diamante (yeah...I know). When we are going down the hill from where we were at, his car started to make a funny noise coming from the front left tire. Chris, being the car moron that he is, goes "Ty, what is that noise!" I say that it sounds like it might be his rotor. He just had his brakes worked on by a shop, they may have mis aligned his rotor or something, causing it to rub on his brake pad. I honestly wasnt sure what it was, I should have had him pull off the road and call his parents.
We get down the hill, we are talking about what it might be, when the car goes BAM, we are sitting at an angle, still moving. Then we see his tire and rim bouncing off away from the car. We stopped right on the stop line in front of this light. We all sit there and look at each other. The lug nuts were stipped off of the wheel assembly, and shot out in who knows how many directions, and his rim was pretty much shot.
Some people driving (obviously gear heads) pulled over and helped us lift the side of the car up, take some lugs off of the other tires to put his old one back on, just to get it out of the road. One of the lugs was completely ripped off.
We assesed what appeared to have happened. I think the shop may have tightened a few of the nuts very good, then left a few not-so-good. So as he drove, they loosened a little bit, causing the tire to move as he drove. That movement cause the nuts to loosen more, causing the tire to eventually rip the nuts off and go flying in the other direction.
It was nuts.
