Carl H wrote:if you are going to use the ka cluster it is much easier to run the ka lower harness.even if you use the rb lower its not hard to splice in the proper wires much less the reverse lights.
Haha damn I knew I forgot something lol.
Andrew85cm wrote:I have a couple of questions.
1.) Where are the reverse lights wires? Are they the wires coming from the transmission. What color are they and where do they connect?
2.) I have 2 sensors coming from the transmission. What are they and what do they plug to? I assume one is for the reverse lights but the other I have no clue. Actually come to think of it my wires were cut and aren't any color so colors would not be useful.
3.) What are the sensors located on the side of the block? I believe they are green. There are two of them and I broke one while removing the engine for the 3rd time. I just was wondering what I broke so I can replace it. They are on the intake side of the engine.
My gauge cluster sucks by the way. I can't get anything to work and I wired and rewired that piece of **** several times. I don't know what the deal is.~ANDREW~
