W O T »
https://forums.nicoclub.com/w-o-t-u75991.html
Mon Jun 15, 2009 10:17 am
Got bored with my old box, and wanted alot more port area, thicker wood, and I was just bored lol. I also went with a different tune. I also sold one of my large sub amps, and my HO alternator and went down to 1 amp, and the oem alt, and got rid of 2 of my 4 HUGE batteries.
I got sick of the HO alt giving me troubles, and the oem one couldnt handle 5000+ rms. But it works just fine seeing about 3000rms with 2 big batteries mounted underhood
The box works out to be 16.6 cubic feet, 225" of port area, tuned to 38hzThe subs are Aq 15's, and the amps are a Visonik V4000XD and a Kicker kx650.4
I completely winged the rear/sides/top of the box, measuring as I went, to try and squeeze as much volume as I could out of the rear cargo area, hance when in alot of pics you see L brackets, they were just for mock up. ince I had to build the box inside of the car, its quite messy
Twas a damn tight fit
My sweet homemade circle drawer lol
Front baffles before attaching
All inside seams of the box were cornered with 3-5 layers of chop fiberglass incase anyone is wonderring what the mess is, its the inside of the box, doesnt matter what it looks like
Game the port a quick coat of rubberized rocker guard to see what it would look like, ended it using spray on truck liner though after I finsihed fiberglassing, the rockerguard was to easy to scratch off. And theres some braces to
Subs
Amp front (the kicker is on the BACK of this panel)
The goal was to keep the amps OFF the box, so I made a metal bracket to hold them a 1/4 off the box
Wired
The subs from heaven (my current rackground pic lolb
Wiring them up
Added some beauty panels for around the box (they werent secured here) and finished paiting the port, heres what you see with the seats folded down.
Just thought Id share, Im sure Ill change it before summers over lol, but it bangs pretty nice
