The Quonset Project.
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
APL
Car: 1991 Nissan Skyline Gts-t
This is the Quonset. Its big and yellow.
Inside.Backside.
RB's are everywhere.
Freshly Pulled.Stale.Rotten.
I was running 15(16spike)psi of boost and bagging way too hard with no fueling for way too long.
This:Turned into this:
So I swapped the lazy *** rb20 turbo with an r33 rb25 turbo:
Turned boost down to stock, then this happened:The dipstick popped out and fertilized my entire engine bay. Way too much blow-by.
The next saturday I decided to do this:
Now im getting parts for this:
A blown r33 rb25 i picked up in January. The #2 cylinder popped.
I have some gtr injectors, still need a top mount fuel rail:
A side mount intake plenum:
Ill try to post updated every day or 2.
APL
GTS was raped of its A/C today.
Before.After.
APL
Pistons arrived yesterday.They are 86.5mm, 0.5mm over. Still oem make.
APL
Started half-stripping, de-greasing, taping and sanding the engine bay for paint.
Hopefully start painting tomorrow.Anyone know the best way/place to hide the fuse box on a 32?
APL
I do!Hid the fuse box today. Alot easier than i though it was going to be.
Pulled all the relays and a few fuses so it would fit through the hole.Had to rip off a bunch of tape on the wiring harness to allow it to make the bend.Test fitted then taped it up again.
Gonna look much cleaner i think.
EL MAMITO USMC
Car: SENTRA SER
nice pics i wish i could do that brake and biuld my car as wished... keep us posted ok good luck
APL
Thanks buddy.
Im gonna spray all over this *****.First thin coat.
APL
Whipped out the SuperClean.
3rd Coat Drying.
Painted the Bonnet Hinges too.
APL
Coming back together.Looks like some ******* satanic bat-mobile ****.
You can see it looks way cleaner with the fuse box hidden. I broke the goddamn outside wiper socket thingy...
skylinegtr20
Car: Skyline
Told you this on GTRC but... looking good. Get rid of that **** called HICAS!!!
APL
Started stripping the block today.
Water lines.
Crushed Oil Pan.
Best puller ever made.
Water Pump.
APL
Slugs in.
Slugs out.
#1. Cracked ring lands and a broken ring.
#2. A ******* mess.
#3. Cracked ring lands
#4. Cracked ring lands and a broken ring.
#5. Cracked ring lands.
#6. Cracked ring lands.
Crank out.
Things.
The rod bearings were ok, but the main bearings were ******.
Bare!
I called a few machine shops today and hopefully the block will be out before the end of the week. Then i have the head to deal with.:thumbs:
APL
Block is at the machine shop, and i picked up a rb26 crank and set of rods.
nicokpe
Good project! Nice pics
SleepR 240sx
Car: 1991 240sx Fastback-S13 SR20det
really impressive project...good luck with it man can't wait to see it finished
APL
Way too much **** arrived.
-ARP head studs-Billet aluminum fuel rail-rb26 444cc injectors(for a start)-walbro 255lph fuel pump-hicas lock bar-water pump-oil pump-nismo adjustable fuel pressure regulator-timing belt-full gasket set
Still much more to come.
I finished with the complete hicas removal, minus the lock bar. I rerouted the hicas pressure line from the pump to the 'p/s cooler' then back to the reservoir. So i dont need a non-hicas p/s pump! Also, started putting back in some of the wiring harness.
AE86_MT
Car: 1985 Toyota Corolla GT-S
Cool project
Return to “GTR Forum / Skyline Forum”
