Races this weekend
Thought Id post this up... Overall, I have to say that I did pretty good, and of course the Q performed pretty good. Me and former Q owner Evan (gniknave) went up. he had his VW GTI.
Overall results- I got 40th out of 89. Take a look at the cars that were there, not bad! Dont ask me what I was thinking on the first 4 runs, I dont know what was going on... I still pulled off a good run the last one.
http://fwscca.com/Solo/Events/...o.htm
Out of the classes. I am in class STX. I am not sure if the guy who got 1st in my class was that good of a driver or if his car was out classed.
http://fwscca.com/Solo/Events/...c.htm
Considering that this car weighs about as much as any 2 other cars combined and is a good foot longer, i cant complain. There were 2 turns that Q struggled to make because of its size. One turn was a super tight S and I had to make that going about 5MPH and had to turn the wheel FULL LOCK... The second turn was a chicane that would take you in a circle, fire you off to the right and then slam you back left. I couldnt whip the car around fast enough to get on the gas... I have a video of that and Ill post it here in a bit, as soon as I get the link from Evan, as well as a couple pics.
The only places the Q had problems was when you had to go slow, and the only places where you had to go slow is because the car is too damn big, not due to lack of grip.. There was a long slalom on the back stretch and the Q dominated that thing. I really think HICAS helped on that one.
The next step is to take the Q on a road course becaues I think if I could take corners at about 50 or more it would do a lot better than taking them at 20.
Suspension review
So as a partial review on my suspension setup, here are some thoughts. Ive been on the track i think 4 times now with my current suspension setup, so Ive got a pretty good idea on how it works... There is the good and bad...
First let me share my current suspension and brake setup.
1994 Q45t with HICAS
- 300ZX 30mm brakes with Brembo rotors and hawk pads, steel lines.- SPL Front and rear upper links, tension rods, subframe spacers- Stillen front strut brace- 28mm front bar (rubber frame bushings and end links), 20mm rear (rubber frame bushigns and poly end links)- Tokico blues shocks with California custom springs.-OZ Racing F1 wheels with Dunlop 9000 tires.- Alignment: Camber= -1.5F, -1.0R, Caster= 5*, Toe=0
The actual suspension feels ROCK SOLID. the solid links give awesome feel under agressive driving and really do not add that much harshness to the overall package. I think ive grown used to it but others ride in my car and I dont think its jarring for them, no one has mentioned anything to me.
The bad part about the suspension is the springs and shocks. The car is definitely under-damped for high performance driving. I also think that for smooth high performance driving you have to have LINEAR springs, not progressive. I think what happens is sort of like a slingshot which makes the car a bear to drive... When you get the suspension loaded going into a corner and then cut it the other way, since the dampers dont have enough power to stop the springs it just shoots the body roll instead of letting up nicely... It doesnt really change the handling but making smooth transitions is almost impossible. Needless the car is a workout but very rewarding.
however the car still rides very nice (i wouldnt say stock but its very nice), so like I say this setup is still great for pretty much everyone.
The cali custom springs are great for 99% of driving. However I do not think progressive springs are the way to go unless you have some dampers that can handle them at the maximum stiffness... I think overall itd be a better idea to have linear springs all around.. Really I need a set of springs that are about 30% stiffer than OEM and a matching set of shocks.. Certainly, progressive springs have their benefits and they make a car ride great and still stiffen up nicely under compression. For the track, they just dont work IMO.
I wonder how the ACTIVE would handle under these conditions... I need to get ross to let me drive his active Q on an auto-X track so I can see how that compares.
Regardless, when it comes time to replace these shocks I will probably ditch the tokicos and fit some coilovers... I think I could find some that would ride pretty nice but would at least give me a more linear handling experience. Of course, that assumes that I cant find an active Q. IT may be easier and more rewarding to find an active Q and transfer all my mods.
Hope you guys enjoy reading this.
