The Q is dead....at least for now
jaeimwhy41
Car: 1995 Infiniti Q45
hey fellas, its been awhile but im back. the 95 is now parked in the garage due to suspension problems. i plan on getting the blues from joe to replace the oem struts. i know they come with the boots as well. i have compiled a list after thoroughly searching the forums and need a vet to double check to see if im missing any nessary parts or if any i have listed come in the package with the blues. all feedback is welcome.
here is the list i made:
4002260U05 (4002260U05 $25.57 $0.00 $19.18 Front suspension - Front suspension - Suspension components - King pin King pin, q45 - q45 w/o active susp, 95-96 1995 - 1996)
5461360U11 (5461360U11 $8.97 $0.00 $6.72 Front suspension - Stabilizer bar and components - Stabilizer bar - Bushing Standard suspension 2 wheel steering 1994 - 1996)
54476-35F20 not found (5447635F20 $34.07 $0.00 $25.55 BUSHING-MOUNTIN)
56112-A0100 (56112A0100 $2.98 $0.00 $2.24 Front suspension - Suspension components - Lower cntrl arm - Bushing Bushing 1994 - 1996 56112A0100 $2.98 $0.00 $2.24 Front suspension - Stabilizer bar and components - Stabilizer bar - Link Bushing 1994 - 1996)
54524-66U20 (5452466U20 $135.55 $0.00 $101.66 Front suspension - Front suspension - Upper control arm - Upper control arm Upper control arm, right - q45 w/o active susp, 95-96 1995 - 1996)
5452566U20 (5452566U20 $135.55 $0.00 $101.66 Front suspension - Front suspension - Upper control arm - Upper control arm Upper control arm, left - q45 w/o active susp, 95-96 1995 - 1996)
56112-V0100 not found (56112W5000 $2.98 $0.00 $2.24 Front suspension - Suspension components - Stabilizer bar - Bushing Lower 1991 - 1996)
5403460U05 (5403460U05 $24.15 $0.00 $18.11 Front suspension - Shocks and suspension components - Spring seat Spring seat - Standard suspension 1994 - 1996)
56115-60U05 (5611560U05 $74.22 $0.00 $55.66 Front suspension - Shocks and suspension components - Shock absorber - Mount bracket Mount bracket - Standard suspension 1994 - 1996)
5432960U00 (5432960U00 $4.07 $0.00 $3.05 Front suspension - Shocks and suspension components - Insulator - Spacer Spacer - Standard suspension 1994 - 1996)
54459-60U01 (5445960U01 $11.00 $0.00 $8.25 Front suspension - Suspension components - Upper link - Bracket Stud plate Upper 1994 - 1996)
55338-60U00 (5533860U00 $28.55 $0.00 $21.41 Rear suspension - Shocks and suspension components - Mount bracket - Seal Seal - Standard suspension 1994 - 1996)
56217-71L00 (5621771L00 $2.60 $0.00 $1.95 Rear suspension - Shocks and suspension components - Shock absorber - Bushing Upper - Standard suspension 1994 - 1996)
55322-60U05 (5532260U05 $40.50 $0.00 $30.38 Rear suspension - Shocks and suspension components - Mount bracket Mount bracket - Standard suspension 1994 - 1996)
55034-60U05 (5503460U05 $22.10 $0.00 $16.58 Rear suspension - Shocks and suspension components - Upper seat Upper seat - Standard suspension 1994 - 1996)
56218-01U00 (5621801U00 $6.60 $0.00 $4.95 Rear suspension - Shocks and suspension components - Shock absorber - Bushing Lower - Standard suspension 1994 - 1996)
55248-01U00 not found (552482Y00A $8.32 $0.00 $6.24 COVER-BOUND BUM)
55240-60U05 (5524060U05 $41.47 $0.00 $31.10 Rear suspension - Shocks and suspension components - Bumper - W/cover W/cover - Standard suspension 1994 - 1996)
Some of the old part numbers have been superceeded by a new part thus the old not found. also one of the numbers has 2 different parts listed. Any help will be greatly appriciated.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Is the mount bracket required?
An a model 20mm rear bar with bushings and links is nice.
jaeimwhy41
not totally for sure what is "required" but i know that since the car is roughly 14 years old now, i should replace everything i can while the car is down...i might do the rear bar...but its not my main concern. i also have to replace the ball joints...i know, i know before you guys give me any grief i should just replace the entire arm, but i would rather just swap out the ball joint and add new bushing because the arm itself is in good condition. Thanks for the quick reply maxnix i knew i could count on you guys...always have.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Are the ball joints available separately? I certainly wouldn't perform the other work without replacing them also, repeated labor being what it is.
captainluigi
Car: 1996 q45t
The Z32 BJ's will work fine but you must use the Z32 BJ seat as well. The NISMO LCA bushing is a good choice. You can check my previous post for a Spicer BJ part # but does not come w/seat. Order it I.o.S.
jaeimwhy41
yes max i planned on replacing the ball joints seperately with the z32's, im picking up the z32 bj's from advance i believe rock auto had moog for 26 ea and advance will price match...no shipping charges. not sure if advance has the seat but will find out when i oreder the bj's.
jaeimwhy41
note to all: i plan on ordering all the parts listed plus the blues from joe.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Why Z32 ball joints when they are not as heavy duty as the G50 ones? I s +100K miles not long enough?
jaeimwhy41
may the q45 gods have mercy on my soul for what i am about to say....price is the reason i am not replacing complete lower arms and thus the reason for the z32 bj's. dont think there are any g50 bj's floating around from what ive read on here...so my only options seem to be low $ versus high $...and i know ill get chewed a new one here shortly for this but im going with the lower$. everything else is going to be from IoS so i decided to keep my costs down.sorry
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
But on the long run....? are we talknig $20 - $50 each for the correct part? That would be 1¢ per mile?
jaeimwhy41
um....the arms run about 250 ea. so 500 give or take. that would be about 450 more than the z32 bj's which im quite sure would be more than 1 cent per mile.
jaeimwhy41
but if you can point me in the direction (the reason i started the thread) of some g50 bj's i would definately grab those...i just dont wanna replace the whole arm.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
THe G50 ball joints may not indeed be available separately, but how will you verify that your arms have not defelected over the years? How worn was the suspension when it was operated? Q45tech warns constantly about long term deflection of metal components over time which is accelerated by worn out bushings and such.
jaeimwhy41
no records of service ever before my ownship of the car...which i nay take your advice on replacing the entire arms because while the car is down i've decided to do some major body work to elimate all rust and give it a fresh paint job...and while sanding down the pass rear wheel well i found BONDO! after sanding the bondo completely off i found tack welds where they pulled the area back flush...which means the dealer lied about no wrecks can you believe that ha! yep i shouldve car faxed the damn thing, but it was just such a beauty that only set me back 4 grand in 05.
captainluigi
Car: 1996 q45t
You are correct. No G50 BJ's cept w/LCA attached. Take a look at the LCA when you pull it. Site down the bushing bore & of course look for any stressed areas where BJ lives. The Z32 will serve you fine. The difference G50 to Z32 is that the taper is 1mm smaller in D not H. However the stress point at base of taper is same. Why you must use Z32 seat. Outside D & W &h of seat is same.
jaeimwhy41
thanks capt...i believe i actually read that from a post you entered awhile back...i have been digging through the archives for about 2 years now just loading my brain with you guys' helpful intellect.
Note: I'm waitng for wes, mike, tech, or any of the other vets to chime in and offer opinions on the list and whether or not i have to purchase all that seperately or if joe has some sort of "kit" - thanks
