180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed Mar 02, 2005 10:37 pm
Order from Nissan, and you will not have to do any of that mess. Just fiddle with the grades that are stamped on your pistons/crank/block and you'll be fine. Only work you'll need to do is fitting the rings picture perfect. Buying from aftermarket brands if you're using stock everything else just isn't worth it if you've gotta go through a machine shop, etc. It'll cost you alot more in the end. Besides, if the place you're trying to buy bearings from has been doing it long enough with a good knowledge of the particular motor that they're selling the bearings for, then they'd have the grade system as well. Another way to think of this, an engine rebuild is very critical. On very critical stuff, skimping is not a good idea. Also, if you're on a tight budget, the length of time it'll take to do the rebuild will also go up. Reason, you just don't got the cash to blow to make it happen in a short amount of time. My rebuild I figured would take about a month or so with my schedule of work and school. Guess what, I'm on month 3 going to 4 (but I'm getting some pretty snazzy parts though) to make it a monster when it rolls out. So take your time. You won't regret it.
