sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Wed Mar 02, 2005 4:39 pm
Thank you fro the response. I happened to e-mail a technician from Clevite and he said:
"The O.E. makes a ton of pistons at once, and they put a number (Grade) on each run. Those pistons are size and weight matched so that they don't put 2 different weight pistons in the same engine. It does not necessarily mean different size pistons. Sometimes it does though I know like in the case of the Chrylser 4.0L jeeps.
In the aftermarket you buy a piston first, then bore your block to fit the pistons, so there are no grades. So as long as you replace as a full sets, and you are not doing a high performance build, you will be fine."
All I really wanna know is, if I have this stock engine (with 70k miles on it), and I wanna replace pistons/rings/bearings, can I just order aftermarket ones that are standard sized, and not have to do any machine work?I really don't wanna spend time/money on machine work.... *sigh* stock is stock dammit.I hope.
sil80
