koukiKA240 wrote: And does the fact that i have the walbro pump change your initial guess at 340hp? that sounds kinda low for 50#
No guesswork here...walbro pump still flows at stock fuel pressure, it's not a "mod" per se, more like insurance that your pump can keep up with you injectors.
Here's the math:
(50lbs X 4 injectors X 95% duty cycle) / .55 BSFC = ~345rwhp
So ~345 is the *safe* max of 50lb'ers...no guessing.
And I agree with "WD"...likeI said in my first post...that's a weird, mis-matched turbo. Tiny turbine for good spool, but big compressor for large top-end flow...that just doesn't mix.
And we've all seen how well the KA responds to a free flowing exhaust, even in N/A form...imagine how much better it is with 100 more RWHP worth of air trying to get out of the motor!
Basically, running a .48 A/R with a Stg I wheel is the equilvalent of running stock exhaust on a turbo car...
I have to agree with your tuner, there's not a good chance of this setup hitting 350. Change turbos, and VOILA!, done deal.
- Brian
