kbflip02 »
https://forums.nicoclub.com/kbflip02-u80964.html
Tue Dec 09, 2008 5:52 pm
to answer some of your questions...u would probably need to get a TT front clip(front half of the car)which should include the wiring harness...u might be able to get away with stock motor mounts but if i was spending the money id upgrade those too...you will need a new transmission...if your going 5 spd get the TT 5 spd and make sure your front clip was a 5spd...if your going auto go with the TT auto...the engine and transmission will both have to be completely rebuilt unless u by some miracle find 1 in perfect working order...you will need a custom driveshaft...and as far as horsepower gain there will not be much if you keep the motor stock...it will barely be noticeable...if you do go that route you will have to upgrade the ecu which also has to come from a TT, upgrade the turbos, upgrade injectors,cams,fuel pump and regulator, pulleys,custom headers will need to be created because z32 headers dont fit the J due to clearance issues with the steering column....you will also have to relocate the battery to the trunk otherwise where will the turbo for that side go...stock Z32 TTs use SMICs and unfoturnately there really isnt much room for a FMIC on the J...but hey since you can afford it im sure something can be done....plumbing for the intercoolers and turbos is going to be a MAJOR pain in the @$$...suspension will have to be COMPLETELY custom because they do not make any aftermarket suspension for the J...on top of that youll need some sort of turbo timer and boost controller as well as a pod pillar w/ a/f gauges as well as oil pressure, etc....
nala all in all if youve got around 15k youll be happy w/ a J pushing around 400 at the crank....take into consideration the TT motor is heavier than the J motor as well as maintainance is higher/more costly...also your looking at some SERIOUS down time w/o your car...granted this project can be a DIY but thats if youve got LOADS of exp working on cars....also if you are having a shop do the work i wouldnt just go by what they say they can and cannot due because if they have never undertaken such a project theres no tellling what kind of snags theyll run into along the way as well as what might be missed or forgotten....
after months of research and weighing the options that is why i opted against the TT swap and decided going another route...im sure i missed something but thats all i can think of off the top of my head...
not trying to talk you out of it im just giving u the facts....if that what you want and you can afford it by all means go for it...id just hate to see you get ripped off as young as you are and as much as you love the J it would be a shame...
on another note you DO NOT need to be racing on the streets...youve got your whole life ahead of you lets keep it that way k...
any other questions feel free to ask and ill answer to the best of my abilities...happy holidays....
