The not needed engine bay items
sr20deTsomeday118
Car: 1991 240sx/se coupe
i have searched and searched for this, but what dont i need in my engine bay that i could remove to free up space ...turbo in the future so i decided to ask before jumping to conclusion and ending up with a big mess...any help would be greatly appreciated...thanks-Bill
boznuttz
Car: MS13
It really all depends on how far you want to go. You could tuck your wiring behind your fenders, remove the charcoal canister and the 4 vacuum lines going to the bottom of the tb (gotta plug them up), you can relocate your battery, remove the windshield washing fluid container, egr junk..... it all depends on how much you're willing to get rid of.
There should be several threads floating around here on how to properly remove emissions stuff.
I removed a lot of junk when I put all my KA-t stuff in....still dirty as hell though!
sr20deTsomeday118
thanks, i knew that charcoal canister could be removed along with the battery relocation but as for everything else well...let the thread searching begin!!
boznuttz
Car: MS13
I removed the stock clutch fan and shroud around the radiator. It gave me a TON of room. I've been using a 14" Zirgo fan, and my car just refused to overheat in the summer while it was NA....and you better believe I beat the living hell out of it, lol.
sr20deTsomeday118
2 weeks and that zirgo is mine...is it a difficult install?
boznuttz
Car: MS13
Nat at all. At first, I was an idiot and bought the 16" thinking I could fit it...but, boy was I wrong. The 14" clears fine and I currently run mine off of a relay so that it is always on. The biggest PITA was removing the fan shroud around the radiator.
Once you get rid of the random vacuum lines, fan and shroud, and random intake junk......you'll have a LOT of room to play with.
DevilMB3017
A lot of people don't use power steering either. That would clear up some room for sure.
scheffler
Car: 92 240 KA-T
92 300zx TT
97 Tahoe
You can remove your AC if you dont use it. the AC asembley weighs like 50 lbs.
sr20deTsomeday118
boznuttz wrote:Nat at all. At first, I was an idiot and bought the 16" thinking I could fit it...but, boy was I wrong. The 14" clears fine and I currently run mine off of a relay so that it is always on. The biggest PITA was removing the fan shroud around the radiator.
sorry for bringing this back from the dead, but im currently trying to install the 14 inch zirgo fan and i need to know how to mount the fan??//
i have no idea where to mount it where it might even begin to sit rightthx in advance!!!!
480sx
Car: 1996 Pearl White 240sx
http://cgi.ebay.com/ebaymotors...ZWDVW
Do not use zip ties. The rest is pretty obvious..
