sexybeasty »
https://forums.nicoclub.com/sexybeasty-u92616.html
Sat May 31, 2008 8:50 pm
This is my first Nissan and first QR25DE, but from my experience it is a good engine. I can't tell if it is "improved" over anything, but researching it revealed that there were problems in earlier versions with spinning bearings- even without boosting horsepower, but that issue has allegedly been resolved in the newer QR25. It's definitely adequate for the vehicle it's in (I have a sedan). It's torquey and pulls like an old school V6 (def not VQ tho), good on hills and with passengers, plus it's smooth, quiet and gets good fuel economy. In Altima form though, it needs to be "uncorked", as it sounds stuffy and cheap. Add an intake and exhaust and you'll be good to go.
If you are interested in increasing power, it's a very strong 4cyl platform, the head is just awesome as far as 4cyl go and the block is like a racing block. You probably knew that already! It has a few weak points, namely it's long stroke, which limits revs to around 7200 even with stronger valve springs and such. I also understand the balance shafts are bad news for these engines and can safely be removed. The QR25 Sentra crowd knows about this. I bought mine for the fuel economy first and price second. Even though I know the QR is good to build with, I'm not interested in making crazy HP, but I like to add a few things to gain some more push from my daily driver. I'd def recommend it if the VQ is not in the picture. Good luck and welcome!
