maxnix wrote:Isn't the tri-mode version the only one that can do this?
I asked many pointed, specific questions about the three different available programs, 1st gear hold wasn't one of them. That makes sense if you were using stock mode, or 1st start only mode (no high shift). I might have gone for tri mode if I'd known. This morning is the only day in several years we've had frost on the grass in the morning, I didn't see a need for 2nd start and I knew I could modulate shifts with the loud pedal, so I thought there was no need for regular program with 1st start. Oh well.
Oh yeah, shifts <are> crisper with this tcu. No offense to Ben @ JWT, but part of the program <must> increase the line pressure. The whole a$$ end of the car squats between 1st & 2nd, even with a light pedal.
1qckser wrote:How does the sprayonaide/ spray/ juice/ da bottle/nitrous fell? is it nice or what? lets here some feedback, I cant wait to hear of long 2nd gear burnouts or pulln m5s from a 60 mph roll:D
Not nearly ready for that, 1qckser. I just left the switch & relay hardware coiled on the ecu for a later install. At minimum, I need to change plugs, check TPS voltage, CPS timing, install a trans cooler & get the diff done before hooking it up.
I need a spare intake manifold, if anyone has one. I want to Extrude Hone it & I'm going to attempt installing the NOS direct port distribution block in the area between the upper & lower intake manifold. That is, if I can regulate a 100shot down to 8 individual 12.5hp nozzles. Shouldn't be a problem.
More people would be running a <JWT> n2o program (50 or 100) if they understood how well engineered it is. I just don't like spraying it into the throttle body if I can help it. Too close & it favors one cylinder or bank more than the others.
Also, does anyone have a spare coil pack ignition-timing-check-thing they want to sell?
