The New Nissan GT-R Spec V
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
I know this is an altima coupe forum but I thought I'd put this out there incase no one knew that Nissan is putting out the GTR Spec V. The price on this puppy is $100K more than the current GTR. According to Nissan, The Nissan GT-R Spec V is the first factory special edition to come from Nissan Japan. While the GT-R Spec V does not add a whole lot performance-wise to standard GT-R cars, its powerful styling enhancements, weight savings and trick high gear boost controller should ensure every unit will be snapped up by the Nissan devout in Japan.
It IS drop dead sexy though
http://www.rsportscars.com/nis...pec-v/
Modified by dangeris at 12:22 PM 2/2/2009
toxik
Car: 09 Pearl White 370z
yeah spec-v is pure sex... but I wish they would of kept the original wheels, I don't like the new ones.
On a side note, the Spec-v is my wallpaper at work and everytime I see it, I shed a tear.
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
Where is the link???
I wanna see it
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Sorry about that,..I edited the OP.
LinkNuc
Car: 2008 Altima Coupe 3.5 SE Super Black 6MT, Loaded minus Moon Roof Deflector
GREAT COLOR!!! (I had a Brickyard 350Z) But the wheels look like dog puke...those are awful...they wouldn;t make an Eclipse look good! I would consider spinners over those....puke puke puke puke
Modified by LinkNuc at 12:57 PM 2/2/2009
08altima35
Car: 08 Nissan Altima Coupe SE 3.5 6Spd Manny Artisan Turbo Dark Slate
i still wish nissan would put a clutch pedal on the floor with a standard 6 speed.
dldjros69
Car: 2012 Evo Gsr
08altima35 wrote:i still wish nissan would put a clutch pedal on the floor with a standard 6 speed.
huh?
crayzitalian3
Car: 2007 Nissan Altima 2.5S
too bad you can't get them here in the U.S.
Sucks balls!
sammyboy
Car: 2008 Nissan Altima Coupe
It is so SEXY
dldjros69
Car: 2012 Evo Gsr
08Coupe
dldjros69 wrote:??????????????????
Think he is saying the transmission is a fancy automatic
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
I don't know..the last couple of posts has got me confused...
sammyboy wrote:It is so SEXY
08Coupe wrote:Think he is saying the transmission is a fancy automatic
Allllllrighty then people...
maxentropy
Car: '08 Altima Coupe 3.5SE
Need only in matte black!
dldjros69
Car: 2012 Evo Gsr
Exactly dangeris
what was 08altima35 talking about?????
08Coupe
dldjros69 wrote:Exactly dangeris
http://forums.gtrforums.com/vb...id=23
THERE IS NO CLUTCH PEDAL ON THE FLOOR!!
From Cnet review and test drive http://reviews.cnet.com/coupe-....html
As for the transmission, the game's automatic setting is far different than the real car's automatic setting. The GT-R uses a six-speed double-clutch manual transmission. There is no clutch pedal, as the dual clutches are controlled by computer. You can set it for automatic shifting or manual, using the column-mounted paddle shifters. In the game, the car shifts like a sports car, maintaining revs so you can keep power. The real car's automatic mode is designed for economy, rapidly shifting up to sixth gear even when you are only going 25 mph.
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Thanks for the link I had no clue that it didn't have a clutch pedal!This GR6 transmission is freakin insane! Wished this was an option on the Zs and ACs
spockrock
Car: Altima Coupe 3.5se
dangeris wrote:Thanks for the link I had no clue that it didn't have a clutch pedal!This GR6 transmission is freakin insane! Wished this was an option on the Zs and ACs
Well Nissan could but replacing the transmission on the GT-R costs 20 000 and each transmission is mated with an engine, so an engine from a wrecked gt-r wont work on your GT-R if you blow your engine.
I think we know why that option isn't on a G or Z or AC.
Zerep
Car: A/C 2.5R
when you say mated do you mean they weld it on or each transmission has a unique set of teeth that dont let be swapped out
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
well I'm sure it's some kind of Biometric Authentication equivalence. I'm sure that that all the trannys and engines have the same components but there is some kind of authentication mechanism that without it, would render both item useless, even when they are physically attached.
Genius I say..Genius!
spockrock
Nope, I am not sure what the deal is but I imagine it has to due with the ECU, at 1600KM you have to bring your GT-R in for a full checkup, and that check up is not cheap, but its to calibrate engine, transmission(regular and racemode), both aliments in standard and in Race mode. This is why some people get GT-R's with a bit more power.
