The new M5 V10.. (E60 V10)
fuzion
Car: Cars.. Web/graphic design.. Yuppp
This engine is nuts.. 507HP 5liter V10..
.. with an 8200 redline
Heres a pic
Another pic..
Read this.. this thing is nuts:
The bi-VANOS variable valve timing featured in the new M5 engine ensures an optimum charge cycle, thus helping to achieve extremely short adjustment times. This means in practice: increased performance, an improved torque curve, optimum responsiveness, lower consumption and fewer emissions. Thanks to the bi-VANOS technology, intake and outlet valves are always opened and closed at precisely the right moment. The naturally aspirated engine uses ten flow-optimised intake trumpets to 'inhale' air from two intake plenums. Each cylinder has its own throttle, a feature typical of racing cars. All throttles are actuated simultaneously and are electronically controlled in order to make the engine highly responsive in the lower speed range, as well as to achieve an immediate response of the vehicle at the high end of the performance spectrum.
The exhaust system of the new M5 engine is made of seamless stainless steel and has a dual-flow design all the way to the silencers. The exhaust gases leave the system through four tailpipes, now a regular M trademark. The exhaust system complies with the European EU4 and the US LEV2 emission standards. The MS S65 engine management system is the central factor behind the V10's outstanding performance and emission data. With more than 1,000 individual components, this engine management system is unparalleled in its package density. Its processors are the most powerful currently approved for use in automobiles, as high engine speeds and comprehensive management and control tasks demand the utmost from this system.
Receiving more than 50 input signals, this system calculates for each individual cylinder and for each individual cycle the optimum ignition point, the ideal cylinder fill, the injection quantity and the injection point. At the same time this system calculates and makes the necessary adjustments for the optimum camshaft angle and the optimum position of the ten individual throttles. The ionic current technology featured by the engine management unit is a technological highlight which serves to detect engine knock, misfiring and combustion misses.
Utilising the spark plug in each cylinder, this system helps to pinpoint engine knock, to check for correct ignition and to detect any ignition misses. Thus the spark plug has a dual function - as an actuator for the ignition and as a sensor for monitoring the combustion process. Ionic current measuring is done directly during the combustion process. The ionic current satellite receives signals from the five spark plugs of each cylinder bank. Dependent on the load, it amplifies these signals and transmits them to the engine management system for analysis, which, for example, perfectly adjusts the ignition point of each cylinder via knock control to the combustion process. All this results in benefits for the driver of the new M5 - lower fuel consumption, higher torque and enhanced performance.
(Above info is from this site)
KDashy
Car: '97 Nissan 240SX
Wow, 10 throttles.
Phax
Car: Control dynamics
I can't wait for a ride when my boss gets his. He has been waiting for the car to come out for two years. The V-10 is nearly the same engine that BMW uses in their F1 program. Man.... There are some things that my 240 will never be, and that M5 is one of them.
ELITEBB127108
damn i love those "M" series
Mr1der
bet it'll break easy.
but man, I'd love to break one.:D
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
unreal. think i can swap it into an S14? and 7spd trans but its not manual :( speaking of M5's have any of you seen then BMW film "Star" with madonna and all? and this car is so much better then the older M5's
fuzion
matt4pl wrote:unreal. think i can swap it into an S14? and 7spd trans but its not manual :( speaking of M5's have any of you seen then BMW film "Star" with madonna and all? and this car is so much better then the older M5's
It's an SMG... Sequential Manual Gearbox, shifting is faster (maybe easier in some aspects?) than your standard manual
"The second generation of the SMG gearbox stands out owing to its even shorter tractive power interruption. The time required for the fastest shift operations is merely 80 milliseconds: Hardly anyone would be able to change gears manually within such a short period of time."
Read this... the transmission system is NUTS:
The new seven-speed SMG gearbox allows gears to be changed using the central gearshift lever or via paddles mounted on the steering wheel. Compared to the previous SMG transmission, gear change times are increased by 20 per cent. The advantage for the M5 driver is a smooth and super slick gear-change, accomplished at speeds impossible to reach even by the most proficient driver, thus smoothing out the traditional imperfections in the power flow through the gears. The M5 delivers an almost jerk-free performance when accelerating from a standstill to its top speed.
Thanks to the SMG's drivelogic function, the driver can choose from eleven gear change options, which enable them to adapt the SMG's characteristics to their very own style of motoring. Six of these programs can be preselected in the sequential manual gearbox mode (S mode), the spectrum ranges from balanced dynamic to very sporty. With the gearbox in the S mode, the driver always shifts gears manually. Whenever the driver activates the Launch Control function, the SMG Drivelogic shifts gears shortly before the maximum engine speed is reached at precisely the right moment and with optimum slip until the M5 reaches its top speed.
In the D (Drive) automatic gearshift mode, the transmission shifts the seven gears automatically, depending on the program selected, the driving situation, the road speed and the position of the accelerator pedal. The seven-speed SMG gearbox not only supports the driver in achieving motor sports performance, but also offers scores of safety features. In critical situations, when the driver shifts down on a slippery surface, for example, the gearbox opens the clutch in the fraction of a second in order to prevent the M5 from swerving out of control in the event of excessive drag torque at the driven wheels.An anti-roll feature prevents the car from rolling backwards during hill starts. A hill detection programme adjusts the shift points on gradients and descents. This prevents gear hunting when charging up a long hill. For down hill runs, hill detection holds the lower gears for longer in order to make effective use of the engine's braking power.
Ubernoober
What, was BMW tired of getting its *** whooped by a primitive pushrod V10, so they had to pull up a V10 of their own?
Mr1der
that's ok, Ford has a monster V10 too:D
they don't have any SMG goodness though:(
