Jacko3 »
https://forums.nicoclub.com/jacko3-u85814.html
Sat Oct 04, 2008 10:38 am
Folks:
I beleive I have stumbled on the final and ultimate combination of mods and characteristics that has yielded me between 30 MPG and 32 MPG in my 2007 G-35 Coupe 6MT this afternoon. However, there are some sacrifices to be made to include (1) droning and loss of some low end torque which comes with the use of the test pipes.
My car is now completely filled with Chevron Techron premium which still has ethanol in it, and I ran it for 60 miles this afternoon at 70 miles per hour--- no WOT, and I achieved a whooping 29 - 30 MPG on the average. In fact, when I reduced the speed down to 60 miles per hour, I hit 32 MPG. This is the first time my car has ever achieved such a feat. I had to reset my MPG calculator on my GPS system, about 5 times to make sure my eye was not deceiving me---well, it wasn't. The least MPG I achieved was 25 MPG at 80 - 85 miles per hour.
As at last week when I used mid-grade Chevron gas, my gas mileage was as bad as when I used BP's premium gas. So, I am done with BP. I am now in love with Chevron.
So, how did I achieve this feat? Well, I have been modding my car carefully over the past 1.5 years, and each modification created a new set of driving characteristics in the car. So, what mods do I have?
1. JWT Pop Charger
2. Z-tube
3. 5/16" Plenum spacer
4. Mrevv
5. Stille Dual catback exhaust
6. Strup Test pipes.
7. Pure Nitrogen in all 4 tires
8. 245 x 35 x 19 ---front tires and 275 x 35 x 19---rear tires.
9. Gas used---Chevron with techron---premium.
10. Engine Oil used---Mobil 1 Synthetic or Mobil 1 EP Synthetic
With the test pipes, running at low speeds and RPMS, makes the car inefficient---you will burn more gas with test pipes at the low performance range--and some low end torque is actually lost as well----so think about this. At higher speeds and higher RPMS, except for the 3rd gear, test pipes do improve fuel efficiency and produce more useable and real horspower at the top end.
70 miles per hour, is the magic number, if you have this same exact mods on, and avoid going WOT too much in your 3rd gear---a quick transition between 2nd and 4th gear using 3rd gear, is a very good way to save gas when on the highway. But surely, when dragging the car, 3rd gear cannot be avoided that much, and so make sure your wallet is heavy. 65 miles per hour is better but unrealistic as a goal on a high way.
So, if you travel a good 40 minutes or more at 70 miles per hour on the highway each day, these mods will change your life for the good. But, if you have short commutes, these mods will cause you to burn a little more gas, except if you remove the test pipes---once test pipes are removed, you will gain back your low end torque, and improved fuel efficiency at lower speeds and lower RPMS, but you may not be able to get the same fuel efficiency at the top end, assuming you have test pipes installed. And removing the test pipes will help spread the torque and Horsepower across a wider band--much of this is a result of the back pressure caused by the cats. And remember, this information is based on the use of Chevron with Techron.
I am also geting ready to replace my PCV valve, air filter, spark plugs, raditor fluids in the next 3 weeks. I wonder how much better the MPG will get once i get the maintenance completed.
I am pleased and ecstatic with the results i achieved today. I accidentally stumbled on the 70 miles per hour magic number, with the exact mods listed above. Is it possible to squeeze out any more MPG from the G beyond what i ahev already achieved? I plan to install STRUP headers next year. I wonder what effect it will have on MPG, horsepower, and torque on both high and low ends of the RPM?
Modified by Jacko3 at 6:21 PM 10/4/2008
