180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Jan 01, 2007 9:10 pm
Ha ha ha. It's one of the first few questions this year. Ok so your CO levels will be dictated by a few things. Your fuel. Run too rich and you'll get more CO, if your HC numbers are high as well, you're getting an incomplete burn and I'd start to look at the injectors for one that's stuck open or a spark plug that's not sparking like it should. Another thing that could be doing this could be your o2, that's one of those parts that will have a signal that will bounce between rich and lean to give a nice median kind of life to the cylinder conditions. There has to be something else that's causing that spike otherwise. I'd suggest looking over the spark plugs and see what they tell you.
