bigperk11 »
https://forums.nicoclub.com/bigperk11-u75808.html
Fri Sep 12, 2008 7:11 am
I just changed the head and the timing is correct the car runs great but when I first start driving it when the car is cold it will over heat and heat up to almost in the red and stay there for like 30 secs or so and then go back down to normal. (no matter what the RMP's) this might happen a few times within the first 10 mins of driving. after like 10 mins it wont happen again. and the temp never get above normal. What can cause this?
I though it was just the thermostat but I have replaced it twice and it still has the same overheating issue. I thought there might be air in the system but im pretty sure I have blead it correctly. (I read through some forums on here to figure out how to blead it). The water pump is new but when I open the radiator cap after the thermostat has opened it does not look like the water if flowing very fast. however it does not overheat at idle. ive let it sit for about 20-30 mins at idle and it never overheated.
I though it might be a issue with my fan having a short and kicking off but the car should not overheat that fast if the fan shuts off when im out in open air and its been really cold here (35-45) at night and it still does it.
Im not sure what to try next or what could be causing this problem. any suggestions for what the cause might be??
