OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Fri Mar 28, 2008 7:25 am
Yeah so I ordered my waterpump and it came in today. I was checking this over on the car, and pulled her out and hmmm steam in the exhaust. Drained the oil, and it’s milky. So I pulled the leaky waterpump and no cracks on the block, and the coolant appeared to be oil free. So I also pulled the intake, rails well everything but the heads, looking for problems none found.
So as long as there are no cracks in the heads or block I am going to move forward with my top end rebuild. The engine itself was pulled with 46k and change so it’s not too bad off.
So beside the new waterpump and obvious gasket I am going to do a stage 2 port and polish on the heads (241, 243, or 317) hmmmm I think I'm going to use the 243 with the thunder racing special
- Dual Patriot Extreme Valve springs and Ti Retainers- Thunder Racing Pushrods (7.400)- Valve Stem Seals
And a CheaTR" - 214/230 .601/.575 117 LSA Cam.
The only thing that sucks is that I have to postpone some of the other work.... body. Not a convenient time at all.
I also gotta send the ECM back out to turn off a few items, but I have 4 codes present, only one being real, and I cant quite figure it out. P0102 MAF Circuit Voltage Low. Iv tried the stock MAF and the brand new ported MAF. No change code wont clear.
