deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Thu Feb 05, 2004 7:01 pm
As far as the ka24e valvesprings are concerned, there are a few simple ways to get some stiff exhausts swapped in. This isnt such a bad idea just to do this and not the intakes, the exhaust valve is massive and spring rate/valve weight is not as good as the intake valves/springs. This can be done very affordably
btw. I can get custom valve springs in any spring rate made for the ka24e intake/exhaust. coming soon!
Good mildly built ka24e head:upgraded valve springssolid lifter conversionreground cammulti-angle valve grindmild port and polish
get your block decked/checkedget some new oem type headbolts (various manufactures)get a quality oem type aftermarket headgasket
That should hold plenty, and flow well
