Housing open, note the mounting screw on the left side of the pic inside the opening:
"H3" bulb removed, white and blue leads connected directly to the bottom of the bulb:
And here is the PIAA bulb with only white lead. If you look closely, the white lead actually terminates on the right side of the bulb in this pic. The left slot opening is where the other lead from the filament terminates:
I have never messed around with anything other than H11s so its always been plug and play for me, Im completely unfamiliar with H3 bulbs or how they behave.
I think all I need to do is get a negative/ground lead connected to the metal base of the PIAA bulb and I should be good to go? If I were to connect this underneath the mounting screw shown in the first pic would the connection be strong enough? Should I solder a lead to the metal base?
Any help is appreciated. I contacted PIAA, sent them the same pics, and they were not helpful whatsoever. They pretty much told me just "no, it wont work" but I think they are wrong.
