Yes, the VG33E and VG30E are the same except bore and stroke.eddiec wrote:i was under the impression the blocks arfe the same except for their bore. in fact a 3.0 could be bored out to 3.3 also you can swap heads between blocks. just a matter of swaping out timing gear and related items. also all the accessory mounting bosses are in the same place on both blocks so why wouldn't the accessories fit.
Mostly due to the fact that NONE of the alignment studs and none of the bolts will line up.eddiec wrote:so what prohibits the DE heads from working on a E block?
and does someone know the bore/stroke differences of the vg30 and the vg33?
