Okay, Recently I moved to Phoenix, AZ where I believe my car has developed a few problems due to higher heat than Oregon.
I installed an aftermarket water temp gauge since I figured I'd have an issue or 2 with cooling. Recently when the engine reaches operating temp the car wants to die sometimes at idle. just die, stabbing the throttle does nothing... Needle dives, and theres no stopping it. If I try starting it immediatly after it dies, the starter just spins and spins... Wait a few seconds and it will start right back up.
Yesterday I came across a Lamborghini Gallardo and raced him, I noticed when I got off the freeway my water temp was pretty steep, 220-225, then the engine died just like I explained its been doing. So I start it back up after a few seconds and drive it to the nearest drive way and cut the engine to let it cool. Ever since then when my car is at normal operating temp, I CANT let it drop below 1700-2000 rpm or else it will die! This means a lot of revving at a stop, a lot of slipping of the clutch, or launching out of stop signs... No joke, if I let it drop below 1700-2000 it will die regardless if Im moving, on the throttle, or just sitting there, it will die! Or, it will idle in a very strange way.. Its like the worst miss I've ever seen, like 2 cylinders, like it only fires every other rotation of the engine. Not enough power to get the car moving. If I can even get the motor to rev at this point and I successfully get the RPM's above 2000 or so, it runs normally, no missing at all, no studdering, the car is normal.
I'm throwing codes 12 and 34, which I believe are MAF and Knock sensor? What does the knock sensor have to do with this, I cleaned the **** out of my maf and its still not working... Could the maf be the problem? I wasnt throwing a code before this problem started.
Car runs perfect when I start it up cold, and drive it for 10-15 minutes.
Any help is greatly appreciated, this car's my daily driver in a new town and its necessary for survival.
Thanks!-Max
PS: Here's the race between me and the gallardo if anyone cares.
http://www.youtube.com/watch?v=b-YRqe28VdQ
The guy had more money than driving skill obviously, I saw/heard him downshift, and heard his motor untill I was too far away... I know he was on it because I let off at about 125-130 and he was going pretty damn fast himself. Reason I think I won is because he is a tard and wasnt in a low enough gear.. Whereas I was in the ideal gear, brake boosting, and ready to rock. Oh well, it was awesome seeing such a sweet car anyway!
