kouki-gymkhana »
https://forums.nicoclub.com/kouki-gymkhana-u9464.html
Thu Nov 02, 2006 8:04 am
Disclaimer: Below you will find my futile attempt to vent the 6 months of frustration I've been dealing with as a result of a string of unfortunate luck, getting ripped off, and not having nearly enough time to work on my car. If you don't care to continue reading, I understand, but if I don't get this off my chest, I'm going to go postal.
Now, awhile back, I learned my HG was blown so I decided to swap it out myself in April of this year. I pulled off the head and sent it out to SpeedLab in Miami, FL to have the head checked, planed, valve seals changed and valves reground. To make a long story short, Mark, the proprietor of Speedlab and, (as I unfortunately have come to realize) absolute ****ing douche bag, broke my intake cam in the process of disassembling the head and refused to compensate me for the loss. He did change the valve seals but did not grind the valves, leaving me with a partially dissasembled head, a broken cam, and a $200 hole in my pocket. I had no time to argue with the ****er back and forth so I cut my losses and have vowed to demonize him on the internet. I hope his business burns to the ****ing ground because he's ripped off ALOT of people.
Anyway, I decide to use this opportunity to upgrade and I pick up some sweet Poncams from Nengun. Now, I'm a medical resident and I work 80+ hours a week so I had to leave the car up on jackstands the engine in pieces in my parents garage since I had to go back to work. I was only able to get vacation for the first time since then this week so I flew down to Miami (from Boston) to put the car back together. My father and I spent Sat-Wed. putting the head back together and swapping in a fresh HG. Last night we finally started it up and it fired on the first crank but was missing pretty badly. We ran it for a few mins while the computer adjusted itself and the missing cleared up a bit but was still present. Took if for a brief run up the block and it's still missing.
This morning, we pulled the plugs and it looks like cylinder #3 is getting too much fuel so we figure it's an ignition problem. We check the harness wires and coils and everything looks peachy. On a whim we break out the compression tester and I have no ****ing compression in that cylinder! AAARRRRGGGGHHH! I know the rings and bottom end are fine so it must be something in the head. I'm thinking that ****er Mark from Speedlab either bent an intake valve or the valve was sticking and is now bent since we ran the motor for a little bit. Regardless, the Looks like I'm going to have to pull off the ****ing head AGAIN for the second time AND I have to buy ANOTHER HG AND my vacation time is up until February. AAARRRRGGGHHH!!!
I'm so pissed right now, I don't whether to laugh at the absolute insanity of this situation or cry myself to sleep. Anyone have tips or advice about how to remedy the valve problem. One person I spoke to said to just drive it and hope that the valve somehow magically will come unstuck or seal itself (I doubt it).
Seriously, I don't know what to do at this point...
