Tryingtogetoutofcars35 »
https://forums.nicoclub.com/tryingtogetoutofcars35-u78767.html
Sat Oct 20, 2007 5:18 am
Hello!!!I took his advise and started looking at the nico forums instead of the 240sxforums! big difference!!! I like it!!
Ok heres the deal. I'm a big pro SR fan... why b/c i've had three in the past and i have nothing bad to say about them. Yes the have there ups and downs just like any other motor but they never broke and i drove the piss out of them!!!
so I went down to tampa to buy the car. Sean was late to put me up at the airport b/c the car was(and still is) low enough to catch the muffler on the lip of any unexpecting main whole. so when picked me up in the M3(very nice) we picked up the S13 and got the car back to his house and fixed it has much has possible befor i hit the road.
we went out for my test drive... diffenitly not as fast as my 310whp SR but with the turn of the boost knob(that isn't hooked up) it could be there...
Sean is a pretty cool guy and he told me everything he knew about the car so i took it all in... I enjoyed the test drive so I'LL TAKE IT...
so even with me being pro SR i took a chance with the CA. Drove it seven hours home with not one problem. the next day didn't far so well. I took my roommate out for a drive it. Did a little second gear roll on into third gear. pulled ok just like it did the night before.
This is my first full boost run since ownership. i didn't boost it all on the way and i have the 30+mpg gas tickets to prove so i get to a turn around since i live on a hwy and the engine stalls when i pushed the clutch in. ummm. started up fine and I drove off no problems. my last SR did this once in awhile so i thought nothing of it.
that night came and I picked a friend to go to the local car meet... had fun just talking to a guy that just came from yokota Air base... on the way back did a 1st gear roll on into 2nd and let off. I hear something going on with the engine so i take it easy to my friends house drop him off and then get it to my house where i called Sean.
he told me that it might be a collasped lifter or a cracked pistion so do a comp test on it and see. I hoped for the lifter but i got a blown motor!
Comp test as read 1: 109 2: 117 3:70 4:135 did #3 twice the first time was only 62
so just to let you guys know i don't harbor anybad feelings toward sean b/c if the motor was bad i don't think it would have made it seven hours but it does suck b/c i did no mods to it within the 24 hrs on ownership so if he had for two more pulls he would be stuck with the blown motor and not me!
Anyways since i took a chance and got bit. on no less then the first day of having it the CA is out!! so i will be parting out the engine shortly either on ebay or on here. in its place will go a VH or VQ. I know that prob. kills you guys b/c this car has had the CA in it since before this forum was even stated but I have other plans.
I've already decide for the turbo kit, chiped ecu, super AFC2, wiring harness, injectors, MAF and IC... which is a complet from stock CA to Top mount 20g turbo set up that can do 400+ whp(on built motor) for only $3000 the only thing you'll need is a fuel pump.
If anyone wants the long block, transmission, HKS flywheel, clutch, shifter LMK
sorry for the long story post and i'm also sorry that a piece of this forums history is going to be parted.
later guysRob
