Nismo_Freak wrote:Sea Foam is your friend.
Ran a good bit through the crankcase with some 10w30 Castrol GTX and a fresh filter... let engine run for about 5 minutes. Drain out ... if it's anything like mine you'll notice a bunch of crap in the oil. (Stupid previous owner believed in 30k oil changes I guess? )
Yeah, I've thought of the old Seafoam treatment. Might need to hit up NAPA and get some.
I'm gonna start by checking the oil pressure. I might do the Seafoam AND drop the pan to see how much crap is in there.
Hmmmm...I suppose a tensioner could be weak due to an oil passage filled with crap.
It still troubles me quite a bit that my oil light is on for a second after startup.
Edit: I've been thinking of switching to Valvoline Synpower, I've heard good things about its detergent additives...I think Fred mentioned it.
Anyway, deCksy, take that upper cover off, remove the guide, check to see if your tensioner is working and then go with Nismo's Seafoam treatment.
Seafoam and PB Blaster are modern ****ing miracles of technology.
