Sil240 wrote:Just Dyno'd the other day.
I was told to use 1 step colder, .020" gap and a shorter ground electrode.
But I'm just going to switch to the same plug everyone is using.
BCPR7ES
Advanced auto only has the Autolite version available: 3922
http://www.autolitecatalog.com/PartDeta ... =A&pn=3922
Champion - RC9YC4 - Stk # 430
You can order these for a 99 Saab 9-3 2.0, according to Sparkplugs.com
Or a Audi A6/S4 5cyl 2.2 95-97/92-94
Spark plugs with V-groove in the center electrode
Bougies met V-inkeping in de midden-elektrode
NGK’s patented V-grooved spark plugs
NGK’s patented V-grooved spark plugs - The principle is technically simple but very effective. A V-groove is situated in the centre electrode of these V-Line spark plugs. This forces the spark to occur at the outer edge of the centre electrode where it is easier to ignite the fuel/air mixture. In addition, the voltage required to produce a spark is reduced. These two features give the benefit of improved ignitability.
NGK V-line spark plugs offer perfect ignition of the fuel/air mixture. Especially in modern low emission lean-burn engines, even under extreme operating conditions.
im gonna be running the same here on my rb26RRRRB wrote:I run Iridium 8's they are the only resistor style plug offered by NGK that are in that heat range.
