mentordrift »
https://forums.nicoclub.com/mentordrift-u39083.html
Fri Apr 18, 2008 6:57 pm
Okay, so I have been reading common posts on this for about the last 2 hours now, and just have a few questions about some of the stuff I have been reading.
What is happening, is any time I go into boost over 9 psi, the engine seems to do a very stong pulsing/lurching ordeal.
HOWEVER, since I haven't taken the car out pretty much at all since we finished the swap, and the few times that I have, boost has been only 7.5psi on a manual boost controller, I still have yet to swap the FPR and fuel pump for my Nismo and Walbro units (The pains of wedding planning).
The car idles a bit high, but I have not had the tachometer calibrated to the RB25 from KA24DE - I think I read that a failing/failed intake manifold gasket can cause this, as well as the lurching/surging/pulsing that I am feeling in the car.
I checked dang-near everything for a boost leak, and all of my connections are good (MAF, etc). ECU is stock still.The car is managable and fine under a certain boost limit, but when boost is turned up, it immediately stumbles around, but is still driveable and does not die out or stall. I thought at first I was overspooling the turbo somehow, but the more I read, the more it seems like a possible fueling issue, followed by the intake mani. gasket.
