silviasgp06 »
https://forums.nicoclub.com/silviasgp06-u61439.html
Sun Apr 11, 2010 8:55 am
if you read my most recent posting before this, I recently preformed a boost leak test. Found a boost leak at the adjusting screw to the FPR but other than that the car check out for boost leaks.
Still having richness issue though!
Its like there is a boost leak but its intermittent.
Last night coming back from ROTC I accelerated to get onto the freeway and it appeared to be running just a little richer than normal but otherwise it was ok.
Then a few minutes into the drive I saw my AFR gauge sweep over to 10 afr(the AEM uego max rich reading) and the car began to bog down. I had to give it more throttle(which also spooled the stock turbo) to keep from slowing down. In the past when the car was all fine the car normally cruises at less than 10% duty cycle, to keep the car at speed I had to add more throttle which resulted in in >20%+ish duty cycle on the commander.
It felt like a boost leak, which I figured it was but the more I drove it on the 30 mile drive home the better the car ran and responded.
What Ive done recently that may be related to the problem:-The other day I cleaned the MAF with MAF cleaner but It drove fine before last night-When messing with the FPR to fix the leak I re adjusted the pressure cause it was a little low
My thoughts:-What are the chances of this being an fpr issue? Like a bad diaphragm or something.Unfortunately they do not sell rebuild kits for this fpr. I plan on opening it up when I get done with work to check. -or Maybe my MAF is slowly going bad
So what do you guys think?
Modified by silviasgp06 at 1:46 PM 4/11/2010
