The gauge of a level of a liquid in capacity for water at Nissan Tiida
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Karik79
Car: Nissan Tiida
Has established to itself the gauge of a level of a liquid in capacity омывателя which really did not suffice.The order of the done works • [url=http: // http://www.nissan-tiida-club.ru/index.php? option=com_fireboard*Itemid=3*func=view *catid=29*id=20089*20082] we Assort the instrument panel [/url]• On a background there are two designated places, but should with what badge there are they 1. above a badge of a headlight, 2. above the indicator " gasoline on outcome (it is well visible on the return party(side) of a background). For the new indicator I have chosen the second• a place on a payment under chip LED and the chip the resistor • it Is soldered LED • As could not find suitable chip the resistor that to left party(side) LED has soldered проводок • the Resistor has taken ordinary and has soldered in it(him) on break of a wire, not having overlooked(forgotten) about to isolate • On a face sheet of a background I a small pine forest have drawn the future indicator (the thin layer of plastic with a paint is removed by him(it))• the thin layer of plastic is removed From the return party(side) as with a paint (from the return party(side) and removed by means of a fine emery paper)Result• it Is checked • Further it is collected the instrument panel how it is told [url=http: // http://www.nissan-tiida-club.ru/index.php? option=com_fireboard*Itemid=3*func=view *catid=29*id=20089*20151] in the appropriate theme [/url] • the Wire has stretched under the panel and has deduced(removed) under a cowl to a flank омывателя......• For the further work the gauge of a level of a liquid from KIA, number of a detail 98520-3F000 was ordered At him(it) two aperture on each side and three with top, for hit of a liquid • Further I have removed(taken off) the right wheel and have removed(taken off) подкрылок (for removal подкрылки on half, it is necessary to turn off 3 bolts on 10 under бампер and to unfasten 7-8 fasteners• At the bottom of a flank has made an aperture has lowered all water (as on evil the flank was full, waited for minutes 10)• To drill it would be necessary so to not get in an edge of rigidity (partition)• Has drilled an aperture 36мм for the gauge that more densely the elastic band sat (drilled a feather for a tree and plastic) • In an aperture about the beginning to be put the sealing ring (elastic band), and then the gauge (the gauge would moisten for that that better пролез)• the Wire from interior deduced(removed) through an aperture above that where the interior includes a tube омывателя a back glass, has got an elastic band and having pierced its(her) wire has inserted back • the Wire has lead(carried out) under a wing in parallel tubes with омывателем • One wire of the gauge has connected to a wire which goes from LED the second has fastened to a body • Well and long-awaited resulthttp://www.youtube.com/watch?v...eddedThe price of all this question Gauge KIA 302,78руб. is ordered on exist, LED 40руб., the resistor 0,5руб bought in radio the goods, 50 руб a feather for drillingWell and my workRate for today 1 $ = 28.7рубBefore making final figure I tried different variants on places where it is not visible at the collected panel
Other photos can be looked here
NODES
Car: 2007 Nissan Versa SL (Blue)
Extremely nice work.
Return to “Versa Technical Discussions”
