So I, along with which seems like more than half of you, have been trying to diagnose/dial in my engine to obtain and maintain a perfect idle.
*CALLING ALL TECHNICAL EXPERTS* !!!
I will give you a scenario. Please take a quick minute to think about it and give your best solution:
- You own a Red S13 hatch equipped with an SR20det, FMIC, 225 walbro,...AND Actress/Model Megan fox is always chilling in the passenger seat for your pleasure. =]
Aight, sound good so far?, Hellll yeahhhh it does! =]
WELL one day you go to start your ride and like always Megan pops up once you insert the key, BUT when the engine starts the idle is horrible and even Megan opens the door, steps out and walks away for good.
Now whos pissed?! I know I am!!
**NOW THE REAL QUESTION: What are the steps to make the proper adjustments to the engine to have AND maintain a perfect idle.
For example, for the sake of argument,
say my tps was at .30
say my iacv screw was all the way down
say my timing was at 20+
What would the steps be to adjust these different areas, IN ORDER!
-Timing first then mess with the idle OR idle first then adjust the timing?
***After I put the engine into "idle adjust mode", by warming the engine,revving it to 2k twice, killing it, unplugging the TPS, starting it, revving it twice again, what should I go to first to adjust the idle, the IACV or the throttle stop screw? Should I adjust the timing first?
WHAT ADJUSTS WHAT?
CAUSE AND EFFECT OF THE TPS/IACV/THROTTLE STOP SCREW/TIMING!
Should I adjust the tps first THEN mess with the iacv?
I notice the engine has 2 idle speeds, What exactly is this?
For example, Say I rev to 4k, the engine will decelerate normal to around 900rpm and stay there like it should BUT after like 15-20+ seconds it THEN falls to like 500-600 rpm and stays there untill revved again. WTF?
WHAT ADJUSTS THAT "second stage idle"? its so confusing.
Also my timing should be 15degrees at idle?, when the engine is revving it increases to around 20 BUT IT DOES STAY at 15 when idling. So whats the deal with this? Is this normal?
PLEASE HELP, NOT ONLY ME, BUT ALL WHO ARE SUFFERING FROM THIS ENTIRE IDLE ISSUE FOR GOOD.
The more info supplied there the better off ALL sr20 owners will be in the future, including myself
- Mike
