first off to sled if you wanna move this to the fiberglassing sticky go ahead just wasn't sure if you wanted it all on there I just got done typing out part of one of my training manuals i've recieved while take an installer course at mobile dynamics in toronto. this is roughly 12 pages of info i just typed from my book to a text document and includes basic info on materials and a step by step install of a spare tire well box i'll type up the rest tomarrow hope this helps some of you out WORKING WITH FIBERGLASSVirtually any part can be molded, cast or formed using composite technology. Since you can control the actual makeup of the matrix, you can dictate the structural or cosmetic characteristics of the part being fabricated. Molding allows you to produce multiple, identical parts in an original negative assembly. Forming or laminating involves producing structures that are reinforced and shaped to fit a specific need. Forming is most often used for high strength speaker and subwoofer enclosures. It is also ideally suited for single objects that are not likely to be repeated. Casting is the method of pouring catalyzed resin into a shaped object that you wish to copy. Often there is no reinforcing material used. Casting is generally used for making small soild parts.
Composite Materials There are two main types of plastic materials. Thermoplastics (like PVC) hod their shape but can be reshaped if reheated. Thermoset materials rely on a chemical reaction to solidify and cannot be reshaped by any means. This is a desireable wuality in the high temperatures found in a vehicle(car sitting in a summer noon sun..very hot inside)
Resins Thermosetting resin comes in many forms. Laminating resin is meant for building up consecutive layers, where the new layer must bond to the previous layer. The resin is "air inhibited" which means that the resin will cure fully except for the surface that is exposed to open air. This allows the next layer to connect to the partially cured previous layer. The most logical product for autosound use is General Purpose Polyester Resin. This is a finisheing resin, which is usually the least expensive and exhibits the best qualities for automotive and autosound uses. It is catalyzed using methyl-ethyl-ketone-peroxide or M.E.K.P, often called "hardner" Finishing resin has a wax mixed into the liquid to allow the surface of the cured resin to dry. In use, the wax will float to the top and keep air away from the surface. Installers can choose to stock a laminating resin and a quantity of "air dry additive", which can be added to resin to convert it to finishing resin. These laminating and finishing resins are known by the chemical term "orthophthalic" or "isophthalic". Ortho resins are the basic general purpose resins, and the Iso resins have greater flexibility and strength for use in molds and more specific applications. Tooling resin is often used for making high volume production molds due to its purity and is not justifiable for retail autosound projects. Since resin is genreally liquikd, it will collect in lower areas fo the project. If work with certical or overhead surfaces is required, a thixotropic agent can be added to increase the viscosity(thickness) of the resin. This type of resin when prethickened is often called "gelled resin". To convert a laminating resin to a gelled resin, you sould add an amount of "Cab O Sil" which is a very light weight, low density fumed silica powder. In the event that you expect to do alot of sanding, "Glass Bubbles" can replace Cab O Sil. This is a hollow silicon dioxide powder that will mex well with polyester resins. Any fiberglass object placed in the vincinity of heat high enough to ignite plywood (near exhuast systems or under the hood) should be formed out of fire resistant resin. This resin appears cloudy white when cured and maintains all the same characteristics.
Gel Coat Gel coat is the outer surface we find on most fiberglass boats. It is usually colored for cosmetic reasons since paint would wear off in time. For autosound purposes, gel coat is intended to protect the mold for multiple "pulls" of duplicate prodcuts. Gel coats have no reinforcing so it should be applied thinly to avoid cracking. After the gel coat is dry, the addition of regular fiberglass mixtures will add the required strength to the part. Ortho based gel coat is suitable for most autosound uses, except where repeated contact with water dictates the use of an Iso gelcoat.
Catalyst Polyester resin is catalysed with Methyl Ethyl Ketone Peroxide, MEKP. When a very small volume of catalyst is added to the resin, the molecules polymerize which calles them to join together. During this process heat is given off promoting the curing of the resin. The amount of hardener used is based on the amount of resin, the ambient room temperature, and the desired time to cure. For example, 1/2% of hardener will cause the resin to gell after about 45 minutes under a 70 degree room temperature. A standard rule of them is Add 2% Mekp to the Resin. Catalyst must be accurately mixed to prevent problems ranging from minor to severe. In colder temperatures, more catalyst will be needed for the same amount of resin. Too much hardner, however, can cause a violent exothermic reaction that could cause cracking or even fire. Wordking in direct sunlight can supply enough heat to rapidly accellerate the curing process so the volume of catalyst must be reduced. Another method of increasin the speed of the cure is by adding Cobalt Promoter to the resin. If you wish to speek the gel time but not the cure time you would use a DMA Promoter. Note: Promoters are mixed with the resin NEVER with the catalyst.
Cleaning & Thinning Uncured resin and other chemicals can be cleaned from brushes and parts with Actone. Do not use acetone on plastic parts as it will rapidly decompose the part. It should never be used to clean plexiglass, car bodies, or any synthetic fabric. Acetone is also highly flammable and evaporates rapidly (No Smoking!) If you need to reduce or thin out a resin, Use styrene instead of acetone since acetone evaporates quickly and will not participate in the curing process. The most common problem when using Acetone as a thinner is cracking of the part. It would most often be used for thinning gelcoat prior to applying it with a spray gun.
ColoringPigments are used to color the resin prior to apllication if desired. IT is highly concentrated and can be mixed to create other colors. Ond drop of this paste like substance will give a distinct hue to a full quart of resin.
Working MaterialsWorking with fiberlass is a relatively expensive method of installation. While the materials used are petrochemicals that have naturally high processing costs, part of the expense is in the disposable material need to preform the work. The following is a list of materials needed to preform work.
Container - Keep on hand a large quantity of half quart containers usually made of paper or plastic. These are often disposed of after containing catalyzed. you can also flex the container after the resin is hardened and it should snap out. Empty coffee cans are best suited for acetone and cleaning containers.
Mixing Sticks - Tonge depressors, popsicle sticks or general paint mixing sticaks are ideal for mixing resins. These are disposable after use and very cheap
Paint Brushes - Very cheap one or two inch paintbrushes are the best choice for apllying resins. Throughout a large project you are likely to throw away 10-30 brushes since they can't be cleaned effectivily ( Acetone will melt plastic paint brushes
Scissors - A good quality pair of industiral scissors is required to cut the cloth and matt. Avoid plastic handles since they will dissolve in acetone as you try to keep them clean.
Plastic drop cloth- Used for sealing resins or to mask off protected areas
Masking Tape - protecting areas from fiberglass resin layer it up over 2 layers for full protection.
Rubber Gloves - Surgical style thin rubber or latex gloves are essential to prevent skin contact with resin and sanding dust.
Wax - Paste style floor or car wax is used to prevent catalyzed resin from bonding to a smooth part(plastic trim panels). PVA or ply vinyl alcohold is used as a spray on mold relase and wax protector and is preferred for intricate parts where it is difficult to rub on wax.
Urethane Foam - This two part liquid foam is mixed 50/50 to produce a hard piece of foam suitable for carving into a shaped model. At a density of 2 pounds per cu. ft. this foam will expand to over 20 times its volume. It is often called "floataion foam" Styrofoam is not useable with fiberglass resin, the resin will melt the styrofoam (Gas melts styrofoam and you call it NAPALM:) )
Mixing Resins A specific amount of catalyst is required for a given amount of resin. While this amount varies based on working temperature, speed, and humidity, this guideline will give you a standard until you develop your own feel for the mix
# of drops of Catalyst By % (at 75* F) 1/2% 1% 2% 4%1oz 2 4 8 162 oz 4 8 16 324oz 8 16 32 648oz 16 32 64 128Gel Time 50min 30min 15min 7minCure Time 75min 35min 17min 8min
Thermoset Types To apply tensile and torional strength, the thermoset resin is combined with a fabric before it hardens. Fiberglass in either matt or cloth form provides this strength. Fiberglass cloth is woven much like ordinary cloth or burlap, when hardened by resin it will have excellent strength characteristics in two directions and will maintain a small amount of flexibility. It can be purchased in weights from 2oz/ sq.yd. to 20oz/ sq.yd. It would take nearly 50 layers of 10 oz cloth to form a one inch this laminate. Coth is best suited to flat surfaces and simple curves since it does not lake to adapt to wild curves.(its prude) Fiberglass matt is a sheet of material made up of small fibers layed in a random pattern and is held together with a powder that will dissolve when saturated with resin. Due to the short strand nature of the matt, it will adapt to complex curves easily, unlike cloth. Fiberglass matt is sold in weights of up to 2oz sq. ft. Thicker material allows for faster buildup of your work, but requires greater care and skill. It will take less than 20 layers of 1.5oz/ sq.ft. matt to produce a one inch thick laminate. Woven Roving is a large version of fiberglass cloth, and is meant to build up bulk quickly. A combination of roving and matt can be purchased as a single unit call "Fabmat" Regular fiberglasscloth and matt is suitable for nearly any autosound application. When certain conditions dictate, other more complex materials may be substituted. Kevlar is a Dupont Chemicals product that gives greater tensile strength with high impact resilience. It is also lighter in weight and very difficult to cut with scissors. Use new scissors only and do not use them on anything other than cutting kevlar. Carbon Fiber is the lightest and most advanced reinforcing material and is used with epoxy resins. Despite its high cose, it offers the most advantage in high performance vehicles where weight and balance is a concern. When used with epoxy resin, the object will bond to metal, glass, wood, and other materials, unlike polyester resins. Epoxy resins are also quite reactive with skin and extra precautions must be taken to prevent skin irritation. Carbon fiber is also far more expensive than kevlar or fiberglass.
Using Composites Certain precautions must be observed when working with fiberglass materials both in the raw material stage and fully cured stage. Chemical reactions to the resins and catalysts are possible. If you are planning to use fiberglassing materials, you should ask your doctor if there is any reason why you might be at risk. Although this is very rare, it never hurts to ask. Ventilation is important where you are working when chemicals in large quantities of for prolonged periods. In addition to proper ventilation a charcoal filtered respirator is benificial. Working outdoors poses no problems if you stand upwind of the vapors. Smoking and open fames are highly dangerous when vapors are allowed to accumulate. Ensure that heaters due not have open flames that could ignite high concentrations of fumes. Rubber gloves should be worn at all times when working with fluid chemicals as some people have allergic reactions. Avoid skin or especially eye contact with any fiberglassing matrials. Once fully cured the fiberglass is inert and becomes very safe. Sanding dust however can cause resperatory reactions and particle mask should be worn during sanding or grinding. Do not store catalyst(MEKP) in metal containers as the may cause spontaneous explosion(This is very important dont need a fire in your garage when your sleeping or not around.)
Alternative Enclosures The non planar cabinet is named due to its shape which results in no sides or walls that are uniform plane surfaces (flat). This type of cabinet is very difficult to build using conventional materials like wood but is easily achieved with the use of composite materials such as Fiberglass, Kevlar, PVC , Carbon Fiber and others. This cabinet will haev very uneven or perhaps curved walls. The benefits of the non planar cabinet are as follows:-Absolute rigidity and strength since irregular surfaces contribute greatly to strength while using far less material. The need for any kind of structural reinforcement is drastically reduced.-Volume is maximized since every cubic inch of space can be utilized in the forming area. The reduction of material also contributes greatly to maximizing enclosure volume and cabinet tuning.-The non parallel and irregular walls reduce or eliminate problematic internal reflections that cause serious problems with bass performance.-Significant weight reduction over other materials.-Increased application of creative shapes and designs.
Fiberglass Subwoofer Cabinets With the great weights that can be imposed on a vehicle by using Medium Density Fiberboard (MDF) for a typical subwoofer cabinet, this reason alone is enough to warrant the use of fiberglass for an enclosure Add the advantage of enhanced internal colume and superior sound quality with the reduced need for space and the fiberglass cabinet would appear to be the only logical choice for any vehicle. Before you commit to producing nothing but glass cabinets, let's consider the stipulations to this typle of cabinet. Fiberglass cabinets are far lighter than any standard wood cabinet. it doesn't macke much sense to build a large cabinest into a Porsche or Ferarrie using wood due to degraded vehicle performance and handling coupled with a gross waste of precious space. A fiberglass cabinet will use available space more efficiently. The unusual shape of the cabinet will reduce or eliminate internal cabinet resonance and dramatically increase bass resolution. The downside to using fibergalss is primarily cost and labor. The materials used for a fiberglass cabinet will be about 4 times the cost of a wood cabinet with quivalent volume. Fortunately the superior sonic performance and unique nature of the cabinet will offset the added cost in the customers mind( Sounds better, looks better) Fiberglass is not suitable as a replacement for flat sided cabinet. Fiberglass gets stronger as there are more curves and irregularities build into the layer. When fiberglass is laid out in a perfect flat manner, the thickness required will be almost the same as MDF yielding no real benifit. Quite simply, if you are working on a sedan with a real trunk make a standard cabinet out of MDF and do just a fiberglass front. One of the most common cabinet styles is the "spare tire well cabinet". By removing the spare tire in the vehicle, a perfect fit, lightweight and easily removable cabinet can occupy the space. This results in the cabinet that is stronger, lighter and better sounding that the equivalent volume wooden cabinet.
Preparing the Vehicle Begin by remocing the interior panels surrounding the spare tire well. At this point you would already know how much volume is required for the subwoofers you intend to use. Now is the time to confirm that the spare tire well will deliver the same volume or more. A simple and accurate method of measuring volume involves pouring measured amounts of water into the spare tire well until the area is about the overflow. Once you know the cubic folume of the water you also know the air volume. If you come up short for necessary colume, it is an easy task to ectend the floor height to gain the remainder. It is better to have too much available colume which allows you to cut the cabinter down later as you find your net volume after constuction. Cabinet colume has a nasty way of coming up short, so it is always best to overcolume the cabinet initially. After removing the water you are ready to prepare the surface to prevent the fiberglass from adhering permanently. Ensure that any objects that protrude into the opening have been covered with duct table and plastic to provide an unbostructed path when the cabinet is removed. Then apply about 5 coats of wax to the entire surface where you intend to apply resin. Mask off the surrounding area with plastic drop cloth to protect the vehicle. Prepare your matt, resin, coloring, and catalyst and have everything on hand and close to the work area.
Step by step1. Mix your resin based on the temperature, gel time and quantity and go to work. You will be applying the first layber of matt, covering all surfaces with a one inch overlap between pieces. Using 2 oz. matt, only one layer is required to produce the "first skin." This will be left to cure for at least 4 hours before it is removed.2. By prying at the edges with screwdrivers or panel removers, the laminate will realease from the spare tire well giving an occasional unnerving cracking sound. The laminate is still flexible since it is quite thin so don't be afraid of bending it to remove it from the vehicle.3. After the laminate has been successfullyremoved from the vehicle try to reinsert it into the spare tire well. If it doesn't not drop right in find where it is catching and grind off fiberglass to allow a very smooth insertion into the tire well and repatch the area to clear the obstruction.4. Now that the cabinet slides easily into place you can licken the cabinet to the appropriate size. Place the cabinet back into the vehicle and applay acouple of largerer pieces of matt and resin to the weaker areas of the cabinet. Once this hardens the cabinet will be stiff enough to allow you to continue working outside the vehicle.5 Set your cabinet on the plastic covered workbench and slip wood shims underneath to prevent the cabinet from warping as you apply more matt. A good trick is to change the color of your resin to all for fast visual confirmation of where you have missed an area. Add matt and resin until the desired thickness is reached and the recheck the volume with measured amounts of water6. The next step is to add a baffle for the subwoofer(s). Lay the cabinet upside down on a piece of cardboard and trace the ouside of the cabinet. Cut the cardboard and trim the edge until it fits inside the rim of the cabinet. Then trace the cardboard onto a piece of 3/4 or 1 inch MDF and cut both the perimeter and the speaker hole. 7. Place the baffle into the cabinet rim and secure it temporarily with afew screws. To seal the baffle into place cut a bunch of 1inch by 4inch strips of matt. dip the drips one at a time into some resin then reach into the speaker hole to place the wet strip into the gap between the baffle and fiberglass wall. This will permanently wond the baffle to the cabinet. As you will be working blind during this process a small mirror will allow you to check your work.8. There will be some excess fiberglass hanging over the edge of the baffle. This is called "flashing" and can be cut off later with a jigsaw. For now leave the flashing attached and pour some catalyzed resin into the gap between the baffle and the flashing to ensure a positive seal.9. Once the resin is fully cured and the complete cabinet is dry, trim of thee flashing and grind down any sharp protrusions. Adisc grinder is the best choice for the task, and be sure to wear a dust mask10. You can finish the cabinet in anyway you like. Since the outside is a perfect fit to the vehicle don't apply anthing except paint or the cabinet will no longer fit the spare tire well. The inside of the cabinet can be damped, filled, or in the case of the plexiglass baffle cosmetically treated.
Stronger than MDF
- 1/4" fiberglass = 5/8" MDF-3/8" fiberglass= 7/8" MDF-1/2" fiberglass= 1 1/4" MDF-1 1/4" MDF weighs a ton
Power Ratings-1/4" good to about 150 watts-3/8" from 150-300 watts-1/2 from 300 and up
