float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Fri Oct 23, 2009 8:11 am
There is supposed to be a check valve in each lifter, and in the head that prevents the lifters from loosing oil pressure. BUT anytime you introduce air into the system, ie; removing the head, then it's normal to get some ticking until the air bleeds out. If it ticks every time you start the car when it's cold, but goes away, then you just need to clean the lifters. If they tick all the time, you either need to dis-assemble them and clean them, OR replace then.
And if your problem is like mine, and it doesn't tick until it warms up and oil pressure goes down, IDK WTF to do. I've been fighting it ever since I rebuilt my motor. I think the bearings are sized on the loose side and I have low oil pressure because of it. IDK how to increase oil pressure with out increase volume, and the only high volume pumps I've heard of are from Toga, and supposedly they're crap.
