Chris28 »
https://forums.nicoclub.com/chris28-u70836.html
Sat Jan 03, 2009 8:53 pm
So I just rebuilt my engine and put a t25 on it. SSA mani, used t25, sr injectors, efi specialist tune, ebay intercooler piping, and for the rebuild a new oil pump, oversize pistons, got the block bored out, new bearings, new rings. Besides the rebuild part, the turbo stuff was basically a budget build.
After messing with my timing a whole bunch then realizing that it was 180 degrees off, it finally started. First of all, I'm retarded and didn't tighten down the intake cam sprocket bolt. This resulted in pretty good idling for about 2 minutes then the bolt backed out enough for the sprocket to come off the timing dowel. Engine shut off by itself, and I realized what had happened after spinning the crank pulley and realizing that the cam shafts weren't moving. After pulling the valve cover and front cover and setting my cam timing back to TDC compression, I put it all back together. Found TDC and set my distributor, and it started again after minor spark timing adjustments. I let it idle at around 1500 for 20 minutes, granted it was a little rough because timing wasn't spot on, then went to pull it into the garage to change the oil. As soon as the engine had load on it, the turbo freaked out. It started clacking, and the noise's speed went up with revs. Sounds like the compressor wheel hitting the housing. Awesome. Also, now that it has load, the not-on timing is very noticeable as it backfires and barely gets into the garage.
At this time I realize I have no lights. Headlights only. No dash lights, no brake lights, no rear tail lights, no hazards, turn signals, nothing. I said w/e, that can be fixed later.
I change the oil, reset my distributor timing, and went to start it up again. I was thinking maybe since the timing was so bad before that's why the turbo was spinning off center, because the entire engine was shaking so badly. I rev it a little, a slight knocking in the turbo, but not as bad as before. I pull out of my garage, noticing that under load the turbo barely knocks. So I have someone following me and I'm just taking the car around the block seeing if it works right.
After realizing that the knocking is still there, I am about to turn around, and i see flashing blue lights behind me. I have no hood,no front bumper, no front license plate, and no lights at all besides headlights. Also, to get to my ecu and engine harness and stuff, I took out my glovebox, which is still in the garage with my registration and insurance card. Even better, my license is in my moms car because I had to show it at advance auto to make a return and hadn't bothered putting it back in my wallet. I have my student ID which I show the cop, as well as my temporary license (wtf) from back when I had just gotten my license and didn't have my actual card yet, so I gave the cop that and explained what was up. He told me he could get me for a lot of stuff, including my "not good" exhaust. I just played it cool and he let me go saying not to drive the car until everything was fixed.
So I say thank you and go to drive off. When I'm back on my street, the motor starts knocking horribly. My e-fans aren't hooked up because I was only going on a quick trip around the block, so maybe it overheated in the 5 minutes I was sitting there waiting on the cop.
Basically tonight sucked. My freshly rebuilt engine doesn't run right and might be toast. My t25 is most likely blown, but I'm not even sure it's getting oil so that could be the main issue right there. I don't even know if the rest of the engine is getting oil, cause if it's not overheating what would cause the horrible knocking noise I heard?
I guess tomorrow I'll set my timing right with a timing gun and check my oil lines to see of they have oil in them, but at this point I'm pretty pissed off at this car right now. Sorry for the rant.
