cory2081 wrote:Well, Daedalus, it's kinda simple. Have you ever taken a piece of plastic and bent it back and forth repeatedly?? It heats up after awhile doesn't it?? Well, that's basically it, only harmonics are on a much smaller scale at a much faster frequency than you bending plastic back and forth. When one of the cylinders in an engine fires, the crankshaft "flexes" or has some "torsion" applied to it. Remeber, this happens many times a second, depending on your RPM. The dampener is designed to absorb or counteract all of this. Because the ASP pulley is much lighter than the stock one, the amount of torsion that the crank sees due to inertia is reduced and b/c the pulley is aluminium, it can absorb and dissipate certain frequencies better than the crank can. I guess that's about as simple as I can explain it.
I've burned myself on quite a few things under the hood after long drives, but never on the torsional damper (not dampener). Conservation of energy applies, but discussing thermal benefits on a damper designed for a street engine seems like fluffing.
I'm not sure what you mean by "the amount of torsion that the crank sees due to inertia is reduced", but an aluminum pulley lighter than stock will increase the stresses on a crank, decreasing its fatigue life. It is probably true that an aftermarket pulley can damp some frequencies better than OEM, but natural frequencies are the ones that need to be damped, and OEM designs target the natural frequencies to prevent coupling.
Aluminum conducts heat far better than steel, but dissipation is another story. I assume "dissipation" means either convection to the surrounding air or conduction to the crank (though I bet the crank is usually hotter than the pulley). I don't think aluminum shows much difference from steel in either mechanism.
I am certain you can improve any part on a car if you're willing to throw enough money into design and analysis (more than what the big car companies are willing to spend on it). Be careful to not sacrifice too much longevity for a small gain in power.
Believe me, it's not that simple.
