The ever popular cold start problem
CA18 RS13
Car: non-fwd japanese sports cars
it seems that lots of people seem to have cold starting problems where the car idles poorly or possibly dies, i am one of them. looking at different posts on the forum most people attribute this to worn intake valves. however i just got my car back from a leakdown test where everything checked out perfectly yet i still have this problem. has anyone found anything else it could be? my plugs shouldnt be the problem (denso IK20's gapped at what they came at), i just had the timing and TPS checked, so what's left? the air regulator? anyone have any ideas?
paul_s13
Try changing the ECU coolant temp sensor, it sits just behind the thermostat housing.
paul_s13
For a quick test, try unplugging the temp sensor and try starting it from cold, if it starts and idles better then you know its no good.
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
I had that problem when my IAA valve wasn't reading metered air. I put a bung in front of the TB and it worked fine. I don't know what your IC pipes look like, but this could be an answer.
PaulOrlando, FL
