The Ebay Buyers Guide/Reviews
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
Well i wanted to start this thread because as everyone knows, products on ebay can be a great find or a complete disaster...
so post what you bought, how much you paid, and your personal review..and maybe even the ebay id of the seller to help out any other nico members... thanks..
lets see what ya got??
badbob2121
well i recently bought the quater glass 180sx overlay sticker/ $10.00 shipped... didnt turn out bad, its just a temp fix to match the 180sx tail center garnish...
danield319
Car: 240sx
badbob2121 wrote:well i recently bought the quater glass 180sx overlay sticker/ $10.00 shipped... didnt turn out bad, its just a temp fix to match the 180sx tail center garnish...
if u want a sil80 why not get these?http://cgi.ebay.com/ebaymotors..._1165
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Why would you want either? They're retarded as f***.
zeause
ive bought like 3 of the cat backs and a couple of the short shifters, the ones with the base on them and theyve all ended up working great. Also bought som e-motor usa coilovers and they rode better and were lower than the tein ha and tein basics that ive had before.
badbob2121
[QUOTE=danield319]if u want a sil80 why not get these?[QUOTE]
like i first posted, it just bothered me having my tails say 180 and my quaters saying 240...simple cheap fix that MATCHES
BUT thats NOT the point of this thread....
badbob2121
ive been looking at buying a ebay test pipe, im not into buying anthing off ebay that isnt just simple cosmetics... ive heard alot of te ebay test's are thin and will heat up so hot they will start to melt your carpet liner... this one looks legit....
http://cgi.ebay.com/ebaymotors...%3AIT
any suggestions?
n240sxfnatic
I bought a test pipe like 3 years ago from ebay. Buy the cheapest one there is, it will work fine. All it is is a metal tube.
#1_Gun
Car: 1992 S13 hatch(DD) 1989 S13 coupe(Project Rustbucket rebuild)
I bought an ebay header and catback system along with a resonator and they sent me a megan racing resonator
works great and fits fine
ILoveMyRHS13
I had an eBay exhaust a while back and it hung really low and the brackets broke off after only about 3 months. Never again.
Wretched
Car: 93' Hatch
I've got an eBay catback...hangers broke off as mentioned before...but I have it tied up with header wrap now. Really can't justify buying a $500 exhaust until this one rots out completely. And the exhaust sounds great, so I'd like to keep it as long as possible.
poshatch
Car: p.o.s. 1990 240sx hatch
tension rodsrucarear toe rodsrear traction rodsheadersexhaustlower control armssubframce collarspoly bushing setclutchpressure plateflywheelss linessway barsmegan v2 short shifter
the exhaust was a complete FAIL, i broke it in two days cause it hung so low, and thats with me tying it up as high as possible
sway bars also failed, didnt come with brakets and were too big to customize the stock ones
everything else works perfectly fine and no problems with the installs
ghx407
Car: 1993 240SX KA-T
Some more contributions; I'll rate fitment and performance/durability - 1 star=crap / 4 stars=excellent
Ebay Intercooler and IC Piping (2005-present) Fitment - *** (cold pipes needed a little persuasion, nothing to be too concerned about) Performance - ****
Ebay NA Header (2005-2005) Fitment - ** (everything lined up perfectly except the EGR bung) Performance - ****
Ebay T2 Manifold (2005-present; customized and reinforced in 2007) Fitment - **** Performance - ****
Ebay T28 Turbo (2005-2007) Fitment - **** Performance - *** (had some shaft play after 1.5 years of use)
Ebay T28 Dump Pipe (2005-2007) Fitment - **** Performance - ****
Ebay T3/T4 Turbo (2007-present) Fitment - * (on one turbo, the hot side stud holes did not line up with the exhaust flange; the other two turbos had perfect fitment) Performance - ** (the turbos have performed remarkably well at 15 psi while they lasted; the first one developed excessive shaft play after 1.5 years, the second one did the same and started burning oil at ~11 months, and I just installed the third one 3000 miles ago; it should be mentioned that the first two turbos saw regular track day duty; all three were ~$150)
Ebay Turbo Oil Lines (2005-present) Fitment - *** (the thread on the oil pressure sensor switch tee had to be cleaned up with a die) Performance - ****
Ebay 3 inch Down Pipe (2005-present) Fitment - **** Performance - ****
Ebay N1 Dual Exhaust (2005-present) Fitment - **** Performance - ****
Ebay 8:1 FMU (2005-2006) Fitment - **** Performance - ** (the first one did not work at all; got a replacement that performed perfectly)
Ebay 6 Puck Clutch (2005-2005) Fitment - **** Performance - * (replaced it the same day it was installed; slipped worse than a worn OEM)
Ebay 25mm Bolt-On Wheel Spacers (2007-present) Fitment - **** Performance - ****
Ebay A/C Vent Dual Gauge Pod (2005-present) Fitment - **** Performance - ****
Ebay Front Bumper Clear Turn Signals (2005-present) Fitment - **** Performance - ****
Ebay Front Fender Clear Turn Signals (2005-present) Fitment - **** Performance - ****
Now for some brand name stuff that has not been up to snuff in my personal experience:
Cometic Head Gasket - (worthless; replaced with a Nissan HG that has worked flawlessly)
ACT Throw Out Bearing - (the HDR6 kit has been a dream since 2005, but once in a blue moon the TOB will crap out on me and I'll have to depress the clutch pedal twice to get the car in gear)
Nissan Suspension Bushings - (Energy Suspension bushings will handle a lot more abuse for a lot less money)
Precision Manual Boost Controller - (occasionally spikes by 3-4 psi when the car first goes into boost)
Flex-A-Lite Fans - (one of the fan motors lasted only 3 years)
Dattebayo
Rating things in asterisks just makes us think you are using more and more complex curses.
silvia_ks_69
Car: 1990 Nissota Silpra
2017 Porsche Macan GTS
hmm ive bought quite a bit of car shiz off of ebay, mostly all brand name parts but ive ventured a few times. I tend to stay away from things that have numerous parts, less that can go wrong.
GTR GrillTRD Shift KnobTension Rods, Front Lower Control, Front Sway (Sucks), Rear upper /lower, traction rods, toe arms, rear sway (also sucks) Godspeed cant make sway bars....HKS Cam GearsBattery Relocation BoxExahust Heat WrapSilvia Key :P
Thats all i can think of right now, the only thing i didnt care for was the sway bars, everything else was definately top notch and a bargain.
Gabes13
Car: rb20det s13
bubble shift knob.that's it.no complaints.
badbob2121
i also bought a BOSS steering wheel HUB adapter/ like $15 shipped... and its great, you can spend more for the nrg, but a hub is such a simple part...
i heard bad things about the boss quick release though
sololock
Car: 91 240sx coupe
I wouldnt buy any suspension off ebay. I have bought OEM small things.
has anyone tried the freedy intake Manifolds? RB
poshatch
sololock wrote:I wouldnt buy any suspension off ebay. I have bought OEM small things.
i have alot of them no name suspension parts
comparing them to wicket tuning (a friends rcua and toe rod) they are practically mirror images of eachother
the design is the same, the dimensions are the same, the thickness of the material is the same and the welds are about the same
IMO they are fine and can take the same abuse as other named brands in of a similar design
however....i will eat my words if one does break i will post it and admit defeat
badbob2121
so i also bought a new steering wheel/hub too.... got it in
320mm steering wheel/28.99 shipped/ awesome quality
boss hub/13.99 shipped/ no nrg, but a hub is pretty simple like i earlier posted...
here is the wheel
its looks great, and really im really impressed with the price...
install was cake too... they said pro instill is recomended... sike... it was real easy, if u need help let me know.....
whyteboi
Car: 1993 Nissan 240sx
i have header, test pipe, cat-back, strut bars and all work and fit great. i dont get the super super cheap stuff tho. ebay is good for name brand and factory replacement stuff sometimes
chukidrifter420
Car: 91 240sx
wow 30 bucks? and its been holding up? and installed pics?
badbob2121 wrote:so i also bought a new steering wheel/hub too.... got it in
here is the wheel
Alday
Car: 1990 S13
ILoveMyRHS13 wrote:Why would you want either? They're retarded as f***.
That's one of the gaudiest things I've seen in awhile. It reminds me of that Famous stars sticker fad crap for some reason
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
sololock wrote:Ihas anyone tried the freedy intake Manifolds? RB
note, i didn't buy it, it came with the misc stuff i got with my rb. i'm going to try and make it better, operative word: try.
badbob2121
what are you talking about??? what is gaudy??
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
Ebay elbow and downpipe w/ flex section for SR20det
Fits fine until you lower your car. The pipe hangs a bit low and needs bent more. Flex section scrapes on a lot of things... Waiting for it to scrape through.Or I'll just take it off and weld it higher so it doesn't scrape through the flex metal yayyy
Ebay test pipe flanges are a bit small, and it could have been longer, but it bolts up fine.Don't worry about your test pipe heating up LOL... It's NOT a cat. It won't trap gasses for long periods of time and heat up like a cat. Safe to remove your cat heat shield after test pipe install.
CXracing intercooler pipe kits are a very good value. Where else can you get Aluminum piping that increases with diameter along it's way to the TB for 75-85 dollars shipped to ur door? (without intercooler or BOV flange win) Includes flanged pipe ends, T bolt clams that don't rust (PA winter), fiberglass couplers etc. Hell, their t bolt clams I recieved are of better quality than PBM. The PBM nuts used tend to strip the T-bolts.
BTW nice LOL smiley Dattebayo
TheBlaiant
Car: Slow40sx
Goes to show not ALL ebay items are bad!Just gotta know where to look!
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
badbob2121 wrote:ive been looking at buying a ebay test pipe, im not into buying anthing off ebay that isnt just simple cosmetics... ive heard alot of te ebay test's are thin and will heat up so hot they will start to melt your carpet liner... this one looks legit....
any suggestions?
The test pipe i got off ebay actually would get soo hot that my shoe melted to the floor i went to lift my foot off the gas and move to the brake and i couldnt move it. I have an ISIS test pipe that is brand new that i dont need if you want to buy it.
I have got a short shifter off ebay for $30 shipped that worked out great for 4 years, also a godspeed intercooler kit for my friends CA setup worked out well too. Other than that i buy quality parts off ebay when they are cheaper.
Didderson
'74 Datsun Z
Are/were you using a stock catback exhaust? The extra backpressure from that could have been the source of your problem. Or running lean will cause high egt's.
Alday
Car: 1990 S13
These ridiculous things lol
