ricebike wrote:ya, i read that too somewhere ... soo just recet ECU codes n see if it pops up again... or u can test the resistance of the injectors
also, u can do that combersome 02 sensor test to see if the LEDs are flashing quickly or slower... but, yea, there is a seperate code for a bad o2 sensor.
that sux to run it bone dry... i don't want to strain the fuel pump by clogging the gas filter n making it work harder.
You know what...I put some seafoam yesterday, and the car did not want to fire after that. I had to give it gas for a while, and stalled a lot. However, I let it sit for like an hour, and I have not had problems since. Sure, it still drives rough at idle, but I don't get a bobbing needle or any stalling...Thank you SEAFOAM...
By the way, How do I test my injcs. resistance? Do I need a multimeter I guess?
