Imissmyturbo wrote:If I could start over I would Turbo the KA. It's got a pretty beefy bottom end stock and with upgraded rods + pistons it's stronger then the SR RB VG. The best part is you don't have to worrie about finding one. Instead of paying for an overpriced swap that could be in bad shape. You can put your money into a good turbo and fuel system. For 1500 bucks you can build your KA and still have 1000+ left over for other parts. I think the most important thing with turboing the KA is the engien mangament. You must get a good standalone if you watn to make power. Haltech, Motech, Tech II or III are good systems to use. If you skimp out on that you will either not make the power you want or you will blow your engine.
Bluefire wrote:I like to think of it this way... All are good motors and great way to make more power.... But I figure if I had my heart set on the Rb25det and if I decide to "settle" on something else, I know that later down the road I'm still gonna want that RB25DET.
-Bluefire
Bluefire wrote:Well obviously if the motor is really stretching your wallet and it means not being able to move back home then it isn't worth it. But like in my case saving up for the Rb25 simply means a lot less going out and eating and drinking at home. Now if I were trying to go for the 26, that would be completely out of my budget cuz then I would have to cut into funds for actual necessities, like school. I guess it all depends on how you are. I'm the type that if I set my heart on something, I'll work my *** off to get it, otherwise I won't be happy. Some people call it obsession, I call it Passion![]()
-Bluefire
-Bluefire
NightXCZ77 wrote:OH MY GOD, DENISE IS ALIVE...and the same old prude.
musicsurfman wrote:AND THE RB20DET AND RB25DET ARE DIFFERENT BLOCKS. PRICING ON THE RB20 IS SLIGHTLY CHEAPER BECAUSE THERE IS LESS MATERIAL INVOLVED, THE SOLID CAM UPGRADE IS CHEAPER ALSO.
