The doors and Windows
nogoodname007
When opening the door, the window goes down a bit and when the door is closed the window goes back up into its slot.
What happens if the battery dies out completely??
Yimbie
Car: 2008 Ivory Pearl Infiniti G37
Hmm... good question. lol I think Infiniti has a safeguard against that. Surely they must've thought of if that ever happens. I have a feeling that they might have some kind of backup system for that.
- Yimbie
onusigep
Car: 2003 G35 / 2008 G37
I asked the same question in another thread.
The top isn't blocked by a hard metal piece, just a seal. So you can open and close the doors when the battery is dead. You just need to be careful closing the door I guess.
At least that's what I was told at the dealership.
Yimbie
onusigep wrote:I asked the same question in another thread.
Oh I see. Well that makes sense also, hehe.
- Yimbie
nogoodname007
thats good, i though it was metal at the top, but it's a seal. good thing.
carman63
Car: 2007 GTI, 2008 G37
Correct, and be careful in freezing weather. I owned a 350Z, same window feature, and in freezing temps the window would sometimes freeze in place. You just had to be careful shutting the door.
azcoupeman
I was told by the dealer that you can safely open the door, but if you try to close it the seal could get screwed up. He informed me that you shouldn't try to close the door until you have jump started the car. Sounds like we are hearing different stories.
carman63
azcoupeman wrote:I was told by the dealer that you can safely open the door, but if you try to close it the seal could get screwed up. He informed me that you shouldn't try to close the door until you have jump started the car. Sounds like we are hearing different stories.
What will most likely happen is, you won't get a good seal initially.
In the case of freezing temperatures, you just have to wait until things warm up. This happened to me several times, I don't recall any long-term damage to the glass or rubber seal.
drivesick
Car: M35 Sport and G37 Sport
Hmmmmm very good question. I remember my old 03 g35 coupe doing the same thing. I sold it before I ever had a dead batt. but I'm pretty sure someone out there has and didn't have a problem.
stejus
Car: Currently, 2003 Acura CL-S 6sp, 2003 Toyota Highlander, 2000 Toyota Sienna
Best thing to due with this rubber seal (and all rubber seals) is to keep them conditioned. This prevents the rubber from drying out and becoming pourous and cracking. It also prevents ice from forming on the rubber.
I use 303 Areospace. Good stuff.
