DRIFTEADOR »
https://forums.nicoclub.com/drifteador-u23379.html
Thu Feb 03, 2005 4:18 pm
actually i believe $61.56 + 46.16 comes out to a little over $100 . thats for a diy kit that you have to solder/assemble yourself. if you have the tools and knowledge all you have to lose it time, otherwise, the tools required to solder it will cost a little more (a $10 radio shack solder iron will not work) and if you mess something up by, for example, soldering at too high of a temperature you'll need extra parts. I couldn't find the price of the built kits for comparison, but a used safc I sells for about $150. and like i said, with the autospeed, if you later upgrade to bigger injectors or a different mafs you'll need to retune as there are no conversions.
s-afc display (notice the graph mode, a lot easier than looking at single entries in a specific rpm points at a time):can display rpm, throttle, air flow and correction %.
autospeed's:
you need separate tuning hardware for either, but an advantage of the safc is that your local import shop is more likely to tune it for you.
