The difference between 300zx N/A and TT
Dorifto_JIN
Car: Nissan 180SX 1991
I guys, I am freshly new in this forum and I was looking for some information but I got absolutely. I am about to do a 300zx rear 5-bolt conversion with the whole brake kit on my S13 and I was wondering what was the big difference between N/A and TT rear breaks/hub. Is it the size of the calipers, the hub, size of the rotors... I see a lot of people putting N/A but no TTs.
Little help puh-lease!
Thanks!
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
I'd recommend posting 300zx questions in the 300zx forum. Here is a good thread to read to learn about the z32 everything-you-need-to-know-about-the-z32-t508376.html
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Since this is going into a 240 and since many of us hadn't done this we can help right here. Nobody uses the tt hubs because they are different spline count for bigger axles. Tho
E only time these are used is when doing a q45 diff swap and utilize bigger axles and hubs. As far as the brakes there isn't any difference in the rear.
Dorifto_JIN
So I guess what I can do is to get a s14 hub and the rest from a Z32?
compactfean
daily
Yeah or you can just get 5 lug conversion hubs for the front.
Dorifto_JIN
Thanks a lot guys!!
