Car: 2007 G35 Sedan
Tire Brand/Model: Kumho V710
Size(s): 275/40/17
Cost: $280 each
Mileage: 300
Summer Performance:
Wet Performance:
Winter Performance:
What were you looking for in a tire?: Track Tires
Would you recommend?: YES
Review:
The best tires in the world unless it rains or you find a puddle. These tires stick stick stick, you have to get them warmed up a bit but once warmed you can corner much faster then you ever thought possible. Also tread life is short since they are rated at 30 UTOG tread life
Car: 2007 G35 Sedan
Tire Brand/Model: Goodyear Eagle RS-A
Size(s): 225/55/17
Cost: came on the car
Mileage: 19k
Summer Performance:
Wet Performance:
Winter Performance:
What were you looking for in a tire?: came with the car
Would you recommend?: Depends,
Review: if you want a nice riding tire that was okay at traction and performance this might be the right tire for you. If you care about performance probably not, once breaking traction it stays broke
Car: 2007 G35 sedan
Tire Brand/Model: Kumho SPT
Size(s): 235/45/17
Cost: $800
Mileage: 22k
Summer Performance:yep
Wet Performance:
Winter Performance:
What were you looking for in a tire?: handling
Would you recommend?:yes but not in 45 sidewall on 17" rim
Review: Handled great car felt faster with these tires vs stock. 45 series sidewall bottomed out on everything!
Very forgiving, once the car breaks traction it recovers predictably and quickly.
Car: 2007 G35 sedan
Tire Brand/Model: Yokohama S drive
Size(s): 235/50/17
Cost: $800
Mileage: 30k
Summer Performance: you betcha
Wet Performance:
Winter Performance:
What were you looking for in a tire?: similar perforamce to Kumho SPT but 50 series so I could drive over speed bumps
Would you recommend?: yes
Review: handled good but ride was buttery smooth. This is the best all around tire.
I had a small patch come out of one tire at around 30k miles while in Tucson, drove back from Tucson - Phoenix on this tire no problems. STRONG tires. Could provide more traction, like the Kumho SPT did. The tread is almost exactly the same, the rubber felt much harder on the S drive vs the SPT. The sidewall on the S drive was softer then the SPT.
Car: 2007 G35 Sedan
Tire Brand/Model: Primewell PZ900
Size(s): 255/50/17
Cost: $100-$150 each
Mileage: 30k
Summer Performance: yes
Wet Performance:
Winter Performance:
What were you looking for in a tire?: 255/50/17 for cheap
Review: This is my second set of these tires, I get about 30,000 miles out of a set. They do everything well. Great traction, good in rain. Very little road noise. The ride is harder then any other tire I have ran. Side wall is very strong. Once traction is broke recovery is quick and predictable. I will probably keep buying these tires for the life of the car. They do everything I want at a price that makes them disposable. If I want to slide the car around or brake stall burn out I don't feel guilty destroying $200-300 worth of tire. They last so long but as they wear traction deteriorates. The last 5,000 miles can be scary.
Car: 2007 G35 Sedan
Tire Brand/Model: Toyo Proxes TRQ1
Size(s): 245/30/17
Cost: $80 used
Mileage: 1000
Summer Performance: yep
Wet Performance:
Winter Performance:
What were you looking for in a tire?: widest tread shortest side wall for drag racing
Would you recommend?: sure
Review: I bought these tires used for use at the drag strip. They hook up good and with 30 series side wall on a car designed for 55 series they really increase the final drive ratio. Putting these short tires on the back of the G is like swapping the rear axle ratio for 4.56 gears. I get into 4th gear in the 1/4 mile on these. They are so short that you must disable the VDC or the car will not move because they are so short.
Here they are next to a 235/50/17
