bvanev »
https://forums.nicoclub.com/bvanev-u8898.html
Sat Jan 24, 2004 5:54 am
Drop the steering column, remove the gauge cluster, remove center trim, defrost vents, kick panel trim, stereo, and climate control. There are 2-3 bolts near the gauge assy, one on each side, and some bolts under the defrost vents, remove them. If all the bolts have been removed the dash will come right out. It will take some tweaking to get it out of the car. Good luck.
