OM3GA »
https://forums.nicoclub.com/om3ga-u39603.html
Sat Feb 20, 2010 11:17 pm
NOTE: It has not been on a trailer ever(unless a tow truck counts).
So ive been wanting to make my build thread for a long time so i guess ill start with this, i'm fairly busy but will hopefully be able to update daily.
My mind was initially set on a nice grip setup when i got the car as well as the (OMG! NA KA is the best setup ever! mindset you know you've thought about it N/A KA with itbs and cams lol )
I bought the car 6 years ago completely stock from the original owner with 188k miles. All records even have the original insurance picture. I drove it around like that for awhile just changed the oil and around 3000 miles later i changed the water pump and thermostat and did a coolant flush. I also bought a cheap ebay short shifter for i think it was $30 shipped which i still have and its been on the car for 6 years working fine amazingly, anything was better than the stock shifter with the badly worn plastic tip. I could literally rotate the shifter in a large circle while it was in gear.
(Picture coming soon)
The first upgrade i did was i bought Cusco motor mounts (which i still have and they work just as great as they did when i first bought them.) and a peak performance transmission mount. The next thing i did not too long after that was a Hotshot ceramic coated header. It was nice i felt a definite mid range gain. (pictures coming soon)
I started researching a little bit more and found out how restrictive the stock intake manifold is, plus its a pain in the a** to work on as you all know. I found out since my friend blew his head gasket on his dohc ka which meant pulling the manifold which was quite a challenge at the time. Now i could do it in no time but anyways I found the company Xcessive manufacturing which made a dohc ka intake manifold which was a great design imo.
I went ahead and bought the xcessive manifold i believe i was the second or third buyer of that manifold since he started making them, the one i got had a small crack in the casting which probably was not all the way through but for the money i spent i wasn't going to take a chance. I explained to him that there was a crack in it and that id need a new plenum as fast as he could get it to me, I sent it out and gave him the tracking info while he sent out the new one with 2nd day shipping! Rich is a wonderful guy there at Xcessive and their parts are top notch.
So anyways the manifold went in everything worked out great with it, i had a thermal gasket on there as well which it came with, i bypassed the throttle body coolant lines also. It was nice i felt a definite gain on the top end with little to no loss at low end. I had to make a custom short ram intake as well as bang the crap out of my hood to make everything fit in there and have the hood close still, i did not mind though since i was going to get a hood vent later anyways.
I bought a Koyo radiatorAgency power hosesNew water pump and thermostatMagnecor spark plug wiresNGK Laser Iridium plugs $10 a piece omg!
All that went in once it was all figured out i took a picture of it which is this here.
I drove it for a while and then figured it was time to change the clutch since it was high mileage i figured i might as well get it out of the way.
I bought a Fidanza flywheel and an Exedy OE replacement as well as a Nismo Clutch Fork pivot. Along with that i also purchased a 1 piece DSS aluminum driveshaft. That went in and i broke in the clutch nicely, response was a lot nicer! (Driveshaft pic coming soon)
I drove it for a few months like this and noticed the front seal was leaking which meant time to replace that! I also picked up a UR pulley.
I left everything at that with the engine since i was happy with it and started working on the rest of the car.
I started by doing a full RS*R polyurethane bushing kit
I first worked on the front, the power brace went in, the polyurethane bushings went in the LCAs, tension rods and the sway bar end links and mains went in as well as the steering rack bushings. The new ball joints also went in the front LCAs at the same time. Driving the car afterward was a lot more responsive as you can imagine having nice stiff bushings over the stock 20+ year old cracked rubber ones.(Picture coming soon)
Next up was the rear bushings, It was a pain first step was burning out all the old bushings. Then after they all burnt out all the metal sleeves had to be cut out which i believe there was 10 total in the spindles and lcas. After that installing the new bushings was easy. The new ball joints for the rear went in as well (89' Nissan Sentra front ball joints). After all that was done i coughed alot and blew my nose which probably equaled about one 205/40/17 in inhalated rubber.
Next on the list was the Solid aluminum rear subframe bushings. The aluminum bushings were still chilling in the freezer as the stock bushings finished burning completely (probably about 20 minutes). The metal sleeves then were cut out and everything was filed and smoothed to get ready for the solid bushings to go in. They went in nicely with a small tap from a block of wood and a rubber mallet. Finally the whole rear end went back in and i drove the car around it felt very good surprisingly responsive even for having stock struts/springs.
After driving for awhile i made up my mind on what coilovers to go with. I ended up deciding on going with Tein super drifts. They had the spring rate i wanted, i knew they were quality and PBM was not out at that time but those would be my second choice. I got my hands on a set which i purchased through FRSport as well as some Megan Rucas since they were more beefy than the Kazama ones since i had them side by side, i also heard good things about their "redesigned ones after their older model.
I also wanted to find some new wheels to put on at the same time the coilovers were installed so i found a nice deal on some 16x7.5 Kosei k1s with a +22 offset. They were light weighing only 13 lbs a piece (and i was not too concerned about fitment back then). I got them custom painted a honey gold color which i thought was a great match with the white paint. I bought four 215/45/16 Falken Azenis rt615 tires for them too which i was a fan of despite their 200 treadwear rating. I wanted to make sure the wheels would clear the coilovers 100% so i went ahead and bought two sets of H&R Extended studs with 20mm hubcentric spacers.
I installed the studs but did not end up needing the spacers with the wheels so i did not run them. Everything went on Including some Tein strut bars, the coilovers were adjusted to have the control arms parallel which i find to be a great grip/response/low to no bumpsteer setup.There are also some Circuit sports tie rods i got temporarily just because my stock ones were completely done. I will be getting some Tein ones soon or possibly the SPL setup.
(The pbm stuff happened way later i used to be running stock arms and then i got Circuit sports and then got PBM lol)
So this is how it looked after all that had happened.
I drove the car for about a year and a half without doing much to it besides changing the oil and doing some stuff to the interior.
I started by stripping out all the interior pieces i did not want and also removed all the sound deadener. I also did a wire tuck and it started to look like this.This is the Drivers side after sound deadener removal and before the tuck.
Heres the other side after the tuck.
More tucking!
Well Thats all for tonight, i will be updating this and redetailing it but i figure i might as well start it now because i have to start a build thread at some point! My monitor is starting to do weird things or maybe im just more tired than i thought.
Modified by OM3GA at 12:40 AM 2/22/2010
Modified by OM3GA at 1:05 AM 2/22/2010
