The current state of my s13 coupe
cypher02xd
Car: '94 mazda mx-6
Don't think I've ever posted my KA up on Nicoclub for people to comment on. I'm currently running the car N/A to learn how to better tune the aem ems so that I can have a good grasp on it when I go to boost it in the winter :D I'll likely be dynoing the car next month just to dyno it and see how it does. Onto pictures! I bought the car with 82,174 ORGINAL miles on it :D
Mod list for those who might care:
Performance/Engine:
■xcessive manufacteuring intake manifold - coated in ceramic chrome
■gloss black powder fuel rail
■xcessive manufacteuring thermal spacer
■Emissions removal
■SS header
■Resonated test pipe
■ISIS dual N'1 catback
■AEM cold air intake
■Ceramic Chrome Valve Cover
Cooling:
■ISIS aluminum radiator
■ISIS metal fan shroud
■ISIS dual 12" electric fans
■Nismo 165* thermostat
Transmission:
■5 speed transmission swap
■Circuit Sports Short Throw Shifter
■New Flywheel
■New Slave Cylinder
■Spec Stage 3 Clutch kit
■Redline MT-90 Gear oil
■Agency Powers Direct Clutch line
Brakes/Suspension:
■Z32 1" BMC
■J30 front big brake kit
■Goodridge SS brake hoses
■Chasebays Brake master tuck with teflon lines
■5 lug conversion kit with s14 hubs/spindles
■Ichiban 15mm spacers with extended wheel studs
■Poly bushings in FLCAs
■Megan Racing Street coilovers
■Megan Racing Adjustable RUCAs
■Megan Racing Traction Rods
■Megain Racing Tension Rods
■Z32 16" wheels
Misc:
■DMAX smoked tail lights
■S14 Seats
■LED Bulbs in the tail lights
■Red leds in gauge cluster
Engine Management:
■AEM EMS
■AEM Digital UEGO Gauge
■AEM 2 Bar Map Sensor
Valiant240sx
Car: 1990 240sx Fastback
Sexy! I'm getting ready to put my ka24de in my sohc car, how do you like that xcessive intake manifold? I've been thinking about picking one up for mine.
cypher02xd
Car: '94 mazda mx-6
I HATE the stock two piece design, I understand where it's "better" for low end torque due to the length of the runners but I feel no appreciatable loss of torque. The car still rips just fine. I'm currently running no idle air control at all and the car will start right up and idle steady at about 1,000 rpms without so much as a hesitation. It also made things easy when I installed my 2 bar map sensor from AEM, it just threaded into one of the extra ports they designed into it ;) All in all, I have no real complaints about it. The only qualm I had was making a proper bypass hose and even now I'm not 100% happy about it since it's a little longer than I want. I found a gates hose from my work that was prebent and then bent it at a different location in order to turn it back. I should get the part number for others because it held me up for a minute figuring it out.
Sorry for the book lol I recommend getting it. and I HIGHLY recommend the AEM EMS. I love it.
Valiant240sx
Sweet, I love feed back like that (I really dont mind reading lol) I'll definitely keep aem ems in mind also even though I wont go turbo till after next march.
cypher02xd
Car: '94 mazda mx-6
Well that's good, because I tend to rant when asked a question. Feel free to ask any questions you may want to ask, I'll do what I can to help. And I'll try to keep this updated as I get closer to turboland.
Tangerine Sky
Diggin it.
nismoracingsx
Car: 1993 White 240sx Coupe
Real clean man. It shows in your car that you take your time.
Jealous of your chase bays brake line kit, I've been wanting to buy one of those for a bit.
sly240
Car: 93 240sx
How low are you? I see that you have the adjusable control arms and such. Do you have the roll center correction ball joints?
