scotty-2-forty wrote: C-Kwik, I did not say that the heat of water changes with increased pressure. I said that "a higher pressure equates to a higher boiling point for the coolant." As the coolant mixture heats up it will expand, thus it builds pressure. In other words, its boiling point increases when it is placed under pressure. We know the radiator cap's duty is to relieve the pressure at a certain 'pressure', not temperature.
I did not say the heat changes with temperature. I said the SPECIFIC heat does not change with temperature. Your statement that coolant under higher pressure can "transfer heat from the cylinder head more efficiently" implies otherwise. Since heat only transfers when there is a difference in temperature and the amount of heat that transfers is related to the amount of heat the medium can absorb until the temperatures become equal (which is what specific heat deals with), a higher pressure liquid will not be able to absorb anymore heat than if it were at a lower pressure since the density does not change (measurably). As I already stated, the exception is IF an engine is putting out so much heat that the flow of coolant cannot absorb the heat sufficiently, in which case it boils. Such a case would likely be rare. And if it were to be occuring, the engine would be running much hotter than is ideal.
scotty-2-forty wrote: Pretty is good! What's wrong with pretty?
Nothing wrong with it. I was merely implying that most people who upgrade their radiator caps don't need to.
scotty-2-forty wrote: Seriously though, but by increasing the opening pressure of the radiator cap's regulator to allow higher radiator pressure it will in effect increase the boiling point of the coolant and reduce bubbles in the coolant system. In turn it improves cooling by circulating liquid and not air, and generally maximizes the cooling performance of the radiator. Everyone knows (at least we do) that air in the coolant passages is not good.
Your statement ASSUMES that coolant is boiling somewhere. But unless the engine gets hot enough to do that, there is no air in the coolant. Therefore, the extra pressure does not provide any help.
scotty-2-forty wrote:Now I should say we are in agreement that the cap should be matched to the radiator being used. I brought up the higher pressure rated cap based on the use of a performance radiator which I could have been a bit more clear; I am basing it on the 300+ crowd which like Papa said it is suggested to upgrade to a racing radiator. Performance radiators are typically rated 22-24 PSI, and professional racing radiators at 29-31 PSI (give or take a few PSI). The highest pressure rated radiator cap that your radiator will accept should always be used. I just wouldn't call it a "band-aid"; it should more be considered a safety net, as once the car overheats by relieving the pressure set by the cap's valve it should be immediately shut down to come to a cool properly. All this brings to light too, it's not a bad idea to upgarde the water pump, to quicken the pace of heat reduction from the engine components through the radiator.
Where are we both saying that a radiator cap should be matched to the radiator's rated pressure? My argument actually implies that a higher pressure cap doesn't provide much benefit for ANY radiator in most cases.
Higher capacity radiators basically do one thing. They increase the dwell time of the coolant so that more heat can be rejected before going back to the engine. Most engines that overheat outside of failures of the cooling systems are because the coolant going back to the engine is not sufficiently cool. Coolant that is at higher temperature cannot absorb as much energy. Thus a feedback loop that causes increasing engine temperature occurs and eventually, the engine overheats. If a larger radiator is added and that causes the engine to be able to run at its normal operating temperature, then the problem was exactly that. Not enough heat rejection occuring at the radiator. And that is not a problem a higher pressure cap can remedy. It will delay the boil-over phase of overheating to a higher temperature, but the temperature of the engine will still be higher than it should be.
Understand that an engine's cooling system's primary purpose is to regulate the engine's temperature. While that encompasses preventing overheating, if your engine is running significantly hotter than it should, then you need to deal with that. A high pressure radiator cap only allows the cooling system to continue to provide functionality while running hotter.
I would agree that it can be a safety net, but if the temperature gets high enough to make a high temperature radiator cap relevant, then I'd probably be pulling into the pit to cool off.
I'll put it this way. Most coolant mixtures boil at about 212 degrees at one atmosphere. The boiling point is typically raised about 3 degrees per psi of pressure. If a radiator cap is rated at 16 psi, then the coolant will boil at about 260 degrees. That's about 80 degrees more than the thermostat's opening temperature. Which is about where the higher pressure cap will show its benefits. I'd be a bit concerned about allowing an engine to run in that range, let alone at any higher temperature. Especially under high loads, and perhaps for extended periods of time.
scotty-2-forty wrote: Performance engines are always going to run higher temperatures due to lots of variables ... it's the nature of the game, thus the reason for the cooling system upgrade(s). I think a good point here is that if one is going to build a higher powered KA engine such as 300hp and up, all of these things need to be seriously considered. BTW, this is a great thread!
For the most part, sure. But there is a lot of overhead built into the engine's internal cooling system. Generally, the biggest limiting factor is the radiator.
PapaSmurf2k3 wrote:I've seen 240s with boiling coolant... Most recently at Carlisle last year.
Sure, but how many were doing so because of faulty cooling systems or not enough heat rejection from the radiator? At the 2002 240 convention, the only incident of overheating I was aware of was a normally aspirated car. Meanwhile my turbo KA was just fine with a stock cooling system. As was a 300+HP KA also running a stock cooling system.
As for the phase diagram, care to elaborate on any point you were trying to make? Noone here is questioning the way the boiling point changes with pressure. My argument is there is no additional heat being carried away by coolant under higher pressures in that of itself...
Sorry if this is getting a little long winded. I'm trying to make sure my argument is understood as it seems to have been misread or misunderstood at least a couple of times.
